Transmission Problems?? Install?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bombers_2007, Sep 11, 2009.
  1. Sep 11, 2009 at 12:01 PM
    bombers_2007
    bombers_2007 [OP] Member
    Anthony
    Panama City
    99 Tacoma
    have a 99 toyota tacoma 3.4L, 5sp, 4wd! Before i took the old one out it wouldnt stay in first gear, grinded in 2nd and made a loud static noise!!
    Bought a used transmission and transfer case, new clutch kit, master clutch cyclinder and clutch slave cyclinder! Took it to a guy to install and got it back!
    It grinds shifting from 3 to 4 almost every time! And grinds when down shifting from 3 to 2, kind makes a weird noise to!
    What should i do? what could it be?
  2. Sep 11, 2009 at 4:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Are you guys bleeding these cylinders correctly? secondly , hope you have a warrantee or return credit from where ever you got it. Stop driving it, go get your money back or another replacement if you can. Whats really going on here may be bad input shaft/shafts Did you grab the inputshaft on the one you bought first ? That'd be the first thing I'd do , check it for end play & side to side , end play being the amount of back & forth slop you feel, a little tiny amount is normal, check the side to side, this should be almost non existent. If sloppy, input shaft bearings are/on the way out & noise from tranny can get pretty noisy between & in gear, & there isn't any thing cheap about getting it fixed. There are some very good used trannys out there ya just have to know what & how to check it, sounds like you got a bad "new" used transmission sorry dude, good luck:cool:
  3. Sep 11, 2009 at 4:17 PM
    98tacoma27
    Ben
    Not Beech Creek
    Bad synchros~ in both of them
  4. Sep 11, 2009 at 4:18 PM
    98tacoma27
    Ben
    Not Beech Creek
    What fluid did you put in the tranny? Was it GL-4 or GL-5?
