Transmission problems need help ASAP
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03doublecab, Oct 4, 2012.
  1. Oct 4, 2012 at 5:35 PM
    03doublecab
    03doublecab [OP] Well-Known Member
    Nick
    Onley, Maryland
    2003 double cab sr5
    pro comp 2.5" leveling kit wheelers 5 pack bilstein 5100's all around goodyear duratrac 265/75/17 method race wheels removed side steps and mud flaps Black grill surround and black bumpers. Red toyota logo in grill Restored headlights 20% tint all around 6k hids. just low beams. will be doing high beams soon
    Hey all,
    went to go to the drug store earlier and as i was coming back i started the truck and when i went to put it in drive i automatically hear loud clunking/ metal to metal sound. as i went to drive away it stalled, and its an automatic transmission. when i let off the brakes and idle it stutters forward slowly. this has NEVER happened before. 4wd seems fine, 85,000 miles. it happens in all gears (drive reverse 2nd and low). any help will be GREATLY appreciated.
    this is also my work truck and i do landscaping so lots of heavy hauling and pulling.
    Thanks in advance
    Nick
  2. Oct 4, 2012 at 5:38 PM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Is there fluid in it?
  3. Oct 4, 2012 at 10:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch Rugged Ridge 3" LED Pods w/Amber covers Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Not clear on what this means. Are you saying that when you engage 4hi they is no "loud clunking/ metal to metal sound "?
    Are you certain its the trans? Could be the rear diff. Maybe sheared teeth either on the ring or the pinion.
