Transmission problems???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smithsquared, Apr 14, 2012.
  1. Apr 14, 2012 at 12:42 PM
    smithsquared
    smithsquared [OP] New Member
    Chinky
    Texas
    06' Tacoma prerunner SR5
    Hi there. I have an 06 Tacoma prerunner with the 5 speed auto trans. I had it flushed at 110000 miles. Here's where my problem comes in.... Whenever you go to take off it is jerking HARD coming out of first into second. You can the. Feel it shift as it goes into each gear. Not as hard but still noticeable. Toyota is saying I need a new tranny. Quote is 5000!!!!! I've never had to replace anything more than a tailight and cab filter in this truck and now I need a new tranny??? Any advice on what might be causing this would really help. Thanks in advance. It has 153000 on it now
  2. Apr 14, 2012 at 12:46 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Flushing kills trannys. Have a trans shop work on it. Not a stealership.
  3. Apr 14, 2012 at 12:51 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Find a reputable independent automatic transmission shop.
