Transmission question
Discussion in '1st Gen. Tacomas (1995-2004)' started by ImpulsedComa, Apr 17, 2015.
  1. Apr 17, 2015 at 7:12 PM
    ImpulsedComa
    ImpulsedComa [OP] Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    I have noticed that my 2002 double cab takes alot longer to shift from 2nd to 3rd gear when it is cold. It only happens between 2nd and 3rd. When its cold out and the truck is a little past fully warmed up, it shifts perfectly and obviously shifts perfectly when it is warm out all the time. . I know the original owner drained the trans fluid and just replaced what was drained. Is this normal behavior or do u think maybe the wrong trans fluid was added. . . Thanks
  2. Apr 17, 2015 at 8:34 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    some vehicles are programmed to hold gears longer when they're cold to get rpm up to help warm up the engine and tranny. I don't know if Toyota does this or not, but if it seems fine otherwise id assume its normal.
  3. Apr 17, 2015 at 10:54 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Mine does that too. Just the way they are programmed. Pretty much most if not all cars (excluding CVT trans cars) will hold gears a little longer when cold
  4. Apr 18, 2015 at 5:07 AM
    gearcruncher
    Canadain bumper technician
  5. Apr 18, 2015 at 8:36 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I was going to ask this same question. Glad to know I'm not the only one, mine will hold in 2nd gear for a good while but shifts out at 2500 RPM and once warmed up, at 2000 RPM.
  6. Apr 18, 2015 at 4:27 PM
    ImpulsedComa
    NJ
    Ok, sounds normal then. . Thanks everyone
  7. Apr 18, 2015 at 7:09 PM
    bighouse01
    bighouse01 Well-Known Member
    NY
    04 DC TRD
    04 double cab here. Same thing, holds til it warm.
