transmission question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cicada83, Nov 30, 2009.
  1. Nov 30, 2009 at 1:19 PM
    cicada83
    cicada83 [OP] Well-Known Member
    Midland, MI
    Retro white SR5 4x4
    Volant ram air, Bestop soft topper
    I have a 2.7 5 speed 08 4x4 tacoma. I have changed the tranny oil in it about 3 months ago to smooth it out a little. Now I have this area on the transmission that always has a little gear oil residue on it. I will clean it and wipe it off but it comes back. Not dripping, but always wet. In the picture it is where the two separate units come together (the brown metal)...maybe transfer case? what is this? Is it bad? Thanks for the help guys.
  2. Nov 30, 2009 at 1:21 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Looks like the sealant may be bad. Did you just drain and fill or tear it down when you changed the oil?
  3. Nov 30, 2009 at 1:22 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    was it leaking before ? make sure the sealing washers are still there and tighten the drain and fill plugs
  4. Nov 30, 2009 at 1:30 PM
    cicada83
    Midland, MI
    Retro white SR5 4x4
    I am not sure what the questions is but I just drained out the bottom and filled in the top side. I can check the plugs but those don't seem to have gear oil around them...
    What do you mean the sealant may be bad?
  5. Nov 30, 2009 at 1:40 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I see Red RTV sealant between the aluminum and steel.
  6. Nov 30, 2009 at 1:44 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    By military standards, this wouldnt deadline a vehicle! LOL
    By my standards, I would try to fix it until it breaks. But really, that doesnt seem to be anything to worry about. As long as there are not continuos drips or rapid fluid loss.
  7. Nov 30, 2009 at 1:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2! No biigie. Just keep an eye on it. If it gets worse, then deal with it. :)
  8. Nov 30, 2009 at 1:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If your still under warranty, it cant hurt to have them look at it.
  9. Nov 30, 2009 at 1:59 PM
    cicada83
    Midland, MI
    Retro white SR5 4x4
    alright, that is kind of what I thought, thanks guys. I did not want to make a mountain out of a mole hill.
