Transmission question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cbirzes, Feb 17, 2024.
  1. Feb 17, 2024 at 12:20 AM
    Cbirzes
    Cbirzes [OP] Well-Known Member
    Colin
    2010 Tacoma 4x4 base
    Just got a 2010, here and there while accelerating it feels like it falls into neutral. Has anyone experienced anything similar?
    The level check plug has a small leak so thinking it could just be a matter of needing more fluid
    Thanks!
  2. Feb 17, 2024 at 12:39 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Falls into manual? Um, is it a manual transmission? Like it revs, like it goes into neutral or the automatic transmission is slipping?
  3. Feb 17, 2024 at 12:45 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Welcome to Tacoma World. If the level check plug has a leak you should definitely take care of that and then do a fill & check for proper level before anything else.
  4. Feb 17, 2024 at 12:50 AM
    Cbirzes
    Colin
    Thanks. Do you have a good link/video on changing fluid?
  5. Feb 17, 2024 at 12:51 AM
    Cbirzes
    Colin
    Yeah I meant neutral long night. But yes it’s slipping, auto transmission. When I hit the gas I get nothing. Typically happening and higher speeds
  6. Feb 17, 2024 at 12:57 AM
    wi_taco
    Adam
    SE Wisconsin
