Transmission raddled in neutral
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarefootBandit, Jul 28, 2010.
  1. Jul 28, 2010 at 6:53 AM
    BarefootBandit
    BarefootBandit [OP] Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    When I am coasting with my 6 speed manual tranny in neutral, it sounds like something is raddling right in the area of my transmission. It's never when I'm in gear.
    Is this normal or should I have it checked?
  2. Jul 28, 2010 at 7:53 AM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    Mine does it also, I don't think its a problem
  3. Jul 28, 2010 at 8:34 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Mine does the same thing. Just the gears meshing together. Nothing wrong.
  4. Jul 28, 2010 at 8:35 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Gear noise in neutral is normal, but you really shouldn't be coasting in neutral. Find the correct gear. It takes too long to get back in gear if you have to take evasive actions.
  5. Jul 28, 2010 at 6:45 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    X2...Also take note when you are costing the transmission is not getting proper lubrication and you can destroy the trust washers.
  6. Jul 28, 2010 at 6:58 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Coasting with clutch in is bad. Coasting in neutral with clutch out is just poor driving habits. Input shaft turns=lubrication. I'm not sure if the tacoma trans is splash lubed or has a lube pump, but either way, if the input shaft is turning, it gets lubed while clutch is out and trans in neutral.
  7. Jul 28, 2010 at 7:00 PM
    macgyver
    Brad
    Canton, GA
    Not true for a manual transmission. For an automatic...yes because you aren't pumping tranny fluid through the engine.
    With a manual transmission your gears are submerged in the fluid so they stay lubricated when they are turning.
  8. Jul 28, 2010 at 7:01 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    He wasn't coasting with the clutch in... coasting with the gearbox in neutral. Perfectly fine, and perfectly illegal in some states (like Arizona). I never saw an issue with it, did/do it all the time when I drive a standard.
    The noise is probably the 6 speed throwout bearing issue. Dealer warranty should fix it... for a while.
  9. Jul 28, 2010 at 9:00 PM
    IamthePhish
    IamthePhish New Member
    Phish
    Brush Guard, Nerf Bars, Rollbar, Custom Black Wheels, Window Tint, Rhino Lined Fender Flares, TailLight Covers, Painted Brakes, Custom Stereo with Custom Subwoofer Enclosure, Offroad Lighting (RollBar and Brush Guard Mount) PDM throwout bearing kit
    Have them Check the throwout bearing, I had to have mine replaced for making noise (rattle/chirp). They will try to tell you that the warranty does not cover the clutch, and since the throwout is part of the clutch it is not covered, at this point remind them that all bearings are covered under warranty; if the still refuse, ask to get the number for the regional manager, or call Toyota Customer Care.
  10. Jul 29, 2010 at 12:03 PM
    2.7taco
    Texas
    The auto will not destroy the thrust washers by coasting as long as the engine is running the converter is turning the pump and flowing ATF through the system.
