Transmission Range Sensor Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jjcale68, Dec 22, 2024.
  1. Dec 22, 2024 at 4:46 AM
    jjcale68
    jjcale68 [OP] New Member
    I’ll try to be as specific as possible
    1. Check engine light comes on
    2. Diagnostic code is P0705 which is the transmission range sensor
    3. Lights on the dashboard that show what gear I am in sometimes light up and sometimes don’t. When they don’t, I can move the shifter back and forth a little bit and the light will come back on.
    4. Sometimes it will flicker.
    5. Truck will drive normally so far. At times the check engine light will also turn off.
    6. Truck has 437k on it.
    7. Question is if this is more the sensor, or wiring and connectors?
    8. Thanks in advance for the help.
  2. Dec 22, 2024 at 6:14 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The fact you can move the shifter to make the problem go away suggests it's the sensor itself. But unplug the sensor and look at the connector pins for corrosion first by all means.
    jjcale68[QUOTED][OP] and Dm93 like this.
  3. Dec 22, 2024 at 4:11 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    This ^^
    IMO the light flickering and coming on when you manipulate the shifter is a smoking gun, sounds like the truck doesn't know where the shifter is at sometimes,
    jjcale68[OP] likes this.
