"Transmission Re-Calbration" TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by terrman, Aug 29, 2009.
  1. Aug 29, 2009 at 9:42 PM
    terrman
    terrman [OP] Active Member
    Osoyoos B.C. Canada
    09 TRD Sport SR5
    HID Headlights Sylvania Silver Stars Nerf Bars XM Radio
    I was at the dealer today and mentioned if there was a TSB for the transmission. I explained the lag, and he check the computer. He said that there is a TSB for years 07-09 for "Transmission Re-Calbration". I have an appointment next friday.
    Anyone out there have this done to there ride??
  2. Aug 29, 2009 at 10:01 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I've not had it done but I'd love to get it done as I feel the lag sometimes. When I slow down and make a turn it throws the RPM's up to like 2300 when i'm barely on the throttle at all. Then it hops down two gears after a long pause in the higher RPM range.
    Thanks for the heads up!
  3. Aug 29, 2009 at 10:10 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Ooh, we need the TSB# or the doc itself, that would be very, very handy.
  4. Aug 29, 2009 at 10:15 PM
    ItalynStylion
    Steven
    DFW, Tx.
  5. Aug 29, 2009 at 10:37 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    probably TSB #0096-09
  6. Aug 30, 2009 at 3:47 AM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    Actually it is T-SB-0277-09. I will try and get a copy up.
  7. Aug 30, 2009 at 4:04 AM
    dalsmthme
    Ithaca, NY
    I attached all 11 pages. sorry for the seperate files. Its the way they get uploaded.
    Reading through it, I am not sure this is my problem.
    • 1.pdf
      File size:
      123.1 KB
      928
    • 2.pdf
      File size:
      95.1 KB
      406
    • 3.pdf
      File size:
      77.6 KB
      316
    • 4.pdf
      File size:
      92 KB
      233
    • 5.pdf
      File size:
      117.3 KB
      244
    • 6.pdf
      File size:
      103.2 KB
      205
    • 7.pdf
      File size:
      107.6 KB
      250
    • 8.pdf
      File size:
      111.9 KB
      177
    • 9.pdf
      File size:
      77.9 KB
      191
    • 10.pdf
      File size:
      102 KB
      214
    • 11.pdf
      File size:
      83.6 KB
      356
  8. Aug 30, 2009 at 4:33 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Nice post.
    My truck drives fine and everything is what I consider 'normal' and 'un-nerving to me' - however, it does act weird sometimes. I've just considered it normal.
    I'm 'on the fense' wether to consider having this done IF my dealership even knows about it.
    For those of you who get it done - post up some info and feedback.
    I definately don't wanna bypass this oppurtunity before my warrantee is up. The question is..."should I or shouldn't I?"
    I've already had the dealer check my tranny fluid for 'hard shifts' (and while they had it for other things). So, it's not like I haven't given them a notice...(laugh).
  9. Aug 30, 2009 at 7:28 AM
    dozer711
    dozer711 Well-Known Member
    Upstate, NY
    '09 DC SB Magnetic Gray Metallic SR5 TRD-OR
    This might be easier,
    TSB-0277-09.pdf
  10. Aug 30, 2009 at 8:37 AM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    soo basically if you don't have a MIL your not getting anything done. Plus I don't want my wire harness all jimmied up..b/c you know it will never go back how it was originally. And that TSB says nothing about reprogramming the transmission
  11. Aug 30, 2009 at 8:45 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I am having a hard time understaning what I might be looking for as a sign I need this. Difficultly shifting? Noise while shifting.
  12. Aug 30, 2009 at 8:50 AM
    TRDKenE
    Kenny
    Richmond, Virginia
    you don't need this if your MIL light is on...apparently there is another TSB for RE-Calibrating the Transmission
  13. Aug 30, 2009 at 8:52 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    Alright, officially confused. What is a MIL light and how do I check if it is on? And any links for that TSB for Re-calibration?
    Ok, figured out what the MIL is, but it should only be on when there is a problem no? How would you check the MIL to see if you need this?
  14. Aug 30, 2009 at 8:55 AM
    TRDKenE
    Kenny
    Richmond, Virginia
    Malfunction Idicator Light i.e Check Engine Light (CEL) Or Service Engine Soon Light (SES)....I wouldnt go drumming up at the dealership trying to get this done b/c they are gonna laugh...this only applies if you have the MIL with the codes listed in the bulletin...there is another bulleting pertaining to Transmission Recalibration...but somehow we got misguided​
  15. Aug 30, 2009 at 8:59 AM
    Janster
    Jandy
    Lancaster, PA
  16. Aug 30, 2009 at 9:01 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    Thanks, just read up on that and put 2 and 2 together. So the light would have to come onand have error code report inthe tsb right? Good, I have no MIL. I would like to see that recailbration tsb however. We need a copy of that.
  17. Aug 30, 2009 at 9:16 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  18. Aug 30, 2009 at 2:52 PM
    dalsmthme
    Ithaca, NY
    This is the only TSB issued right now for a Tacoma trans issue....
  19. Aug 30, 2009 at 5:53 PM
    wvtac0
    wvtac0 Well-Known Member
    Eastern Panhandle - WV
    17 TRD DC Sport
    Thanks dozer711 for posting the TSB. With all respects to the previous postings, the TSB states that "Some 2005 - 2009 model year Tacoma vehicles may exhibit a MIL "ON" condition.....". The key word here is "may". Just yesterday in my driveway, I started the tacoma, put my foot on the brake and shifted from "Park" to "D". You would think that the whole transmission was going to fall out.
    I am going to call the dealer tomorrow and see if they will accomplish the test procedure.
  20. Aug 30, 2009 at 6:01 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    My truck has the tranny lag, and I have noticed it idles VERY differently in neutral than when I shift to drive. Does this constitute harsh engagement?
    I'll probably bring it up to the local service fellows and take 'em for a ride to see if I can duplicate the issue.
