Transmission service advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 71Shovelhead, Apr 18, 2025.
  1. Apr 18, 2025 at 7:51 AM
    71Shovelhead
    71Shovelhead [OP] Member
    2008 Tacoma TRD Sport Double Cab
    I have a 2008 Toyota Tacoma TDR with 117300 miles on it. My question is Should I have the transmission serviced? I currently have NO tranny issues at all and want to keep it that way. I'm receiving conflicting information about doing the service. One transmission shop was drooling and wringing their hands in anticipation, while others have advised against it saying that draining the fluid, dropping the pan, messing with the screens, changing the filter and replacing the fluid could cause unforeseen problems.
    So, what say all you wise and knowledgeable Tacoma owners?
    Thank you for your time.
    Terry
    HondaGM likes this.
  2. Apr 18, 2025 at 8:07 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    You should click on the tutorials above and read about the diy tranny maintenance for 2nd generation. How-to’s
    NmapFE, HondaGM and 2015WhiteOR like this.
  3. Apr 18, 2025 at 9:01 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    At 117k miles I would just start doing a simple drain/refill once a year until you notice the fluid comes out the same red as it goes in, and then starting doing the drain/refill every 30k.
    NmapFE and HondaGM like this.
  4. Apr 18, 2025 at 10:22 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    These transmissions aren't that brittle, I wouldn't worry about dropping the pan and changing the filter.
    The concerns about changing fluid and causing problems is kinda outdated. That was a problem back in the 80s and 90s, they're built much better nowadays.
    The 4.0 auto transmission is basically the same as what came in the 1st gen Tundra V8. Now it's behind a V6.. pretty bullet proof..
    Jimmyh, wmb67, NmapFE and 1 other person like this.
  5. Apr 18, 2025 at 10:24 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    You serviced it before ...
  6. Apr 18, 2025 at 12:13 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It probably won't make any difference either way. I simply don't change transmission fluid. Never have and I've been driving for over 50 years. In fact, I don't know anyone who has ever changed their fluid. I have 4 vehicles with a combined 700,000 miles on the factory fluid, 255,000 on the Tacoma. I've never had a fluid related transmission issue in a few million miles of driving. Electrical problems, yes. Fluid related no. I've never seen any data that shows changing it prolongs transmission life. They die when they die and I'll just save my money and replace/rebuild if that ever happens. If one of mine dies tomorrow I'm way ahead financially.
    When you change it, you only get 1/3 to 1/2 of the old fluid out anyway. If your transmission is in good shape, and at 117,000 miles it should be, changing it won't hurt anything. BUT... if your transmission is compromised and close to failing anyway changing the fluid will speed up the process. Keeping the old fluid in there buys you some more time before it dies.
    A reputable shop won't change it on a vehicle that old unless you insist and maybe not even then. They've had too many customers wait until the transmission is giving them issues then bring it in to get the fluid changed hoping that will fix the problem. Then when it dies 3 days later then come back threatening to sue the shop. It's just not worth the risk to most shops.
    Jimmyh and Spindifferent like this.
  7. Apr 18, 2025 at 9:25 PM
    Owenhall
    Owenhall Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    I would personally just drop the pan and change the filter and fluid (clean the magnets)I would not flush it sometimes it seems transmissions don’t like being flushed. The I would just change it frequently a few times to clean out the old dirty fluid and then start Changing it every 30k.
  8. Apr 19, 2025 at 12:59 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    I had a fluid flush done at 117,000 with OEM Toyota WS fluid. Currently at 136,000 with no issues or after-effects. Going forward, I plan on doing a drain-and-fill every 30,000 miles. No plan to drop the pan or messing with filter. FWIW: Truck purchased used with 104,000 miles.
    NmapFE likes this.
  9. Apr 20, 2025 at 4:01 PM
    Scrapla
    Scrapla Rebel Without a Clue
    South Florida
    2007 Tacoma PreRunner 4.0 V6
    1.5" lift, ARB bumper
    If you don't have issues leave it alone. If you are curious what your current fluid looks like just do a drain and fill. My truck was starting to get a shudder which felt like torque convertor shudder. I just did my first drain and fill at 150k miles. I plan to do another one during my next oil change. My fluid came out dirty but not horrible. I was debating on dropping the pan to clean the magnets and replace the filter but decided on just a drain and fill. I haven't driven it enough to call it good but if multiple drain and fill's fixes my shudder I will definitely update. On a side note I use to own a few first gen Saturn's years ago. Their automatic transmissions had a small external filter like a oil filter and it was such a breeze to change and monitor your fluid.
    Williston likes this.
  10. Apr 28, 2025 at 2:46 PM
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    I had the trans flushed around 130k. Dropped the pan, cleaned the magnets and changed the filter around 200k. Running fine at 235K, might do another pain drop around 250-270k. Don't overthink it.
    Filter doesn't really need to be changed, it's a mesh that stops particles which then fall down to the magnets. If it's damaged or clogged, you have bigger problems.
  11. Apr 28, 2025 at 4:31 PM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    i did my 2010s over a year ago with over 100,000 miles for the first time, after researching on here. I had a transmission shop with a good reputation do it. I had the pan drained, pan/magnets cleaned, filter changed, and refilled. No flush. He said everything was normal inside and no signs of abnormal wear. I was nervous to do it too, but the shop owner told me if i wasnt having problems before doing it, he guaranteed i wouldnt after he worked on it. He said the 2nd gen tacoma automatic is a very, VERY good transmission. I have had this truck for over ten years and it has never let me down.
  12. Apr 28, 2025 at 4:51 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    At 117k never been touched and shifting good. Do it right.
    12 quarts of Toyota WS fluid, an OEM Toyota pan gasket, OEM filter screen (and o ring).
    Drain n Drop the pan, clean magnets, replace the filter. Fill pan with 4 quarts, then pump out 2 quarts at a time till 12 new quarts have been put in via cooler lines like the proper DIY (replacing as you go). Let cool then do temp check drain which will net around half a quart to almost a quart.
    Did this on my mom's 07 4runner a few months back with the same 5speed as our Tacoma at 250k that had only ever had a proper (non forced) fluid swap at 110k. Damn thing shifts better than my 2013 with 100k less miles. Pan magnets had minimal gunk and fluid looked okish but definitely needed changing. She's good to go for another 100k
