Transmission service or no
Discussion in '1st Gen. Tacomas (1995-2004)' started by hardtaco, Jun 8, 2009.
  1. Jun 8, 2009 at 5:50 PM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Fellas,
    My 2004 Tacoma PreRunner 3.4L has over 66,000 miles on her, and I was wondering if I need to do anything to the auto tranny at this point in it's life. Sometimes when you have things "serviced", it can lead to problems. What do you think should be done, if anything at all?
  2. Jun 8, 2009 at 6:00 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Just do a drain and refill, it's supposed to be done every 2 years or 30K miles, whichever comes first.
  3. Jun 9, 2009 at 5:33 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Is this something that I can do myself? Or do I need some fancy transmission doohicky equipment? What all is involved?
  4. Jun 9, 2009 at 7:02 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    1/2 socket and a socket wrench and transmission fluid
  5. Jun 9, 2009 at 7:05 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Drain and refill, do not have it flushed!
    If it's really dirty, change it again a month or so down the road.
  6. Jun 9, 2009 at 7:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    drain and refill is simple. when i did mine...i went the extra mile and unbolted the pan and cleaned the magnet off, and also cleaned the filter screen with brake cleaner...made new rtv silicone gasket, then bolted pan back up. it wasnt bad either.
  7. Jun 10, 2009 at 6:07 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    What kind of tranny fluid do I buy, and how many quarts?
  8. Jun 10, 2009 at 6:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im pretty sure you'll need the toyota t-iv(t4) fluid, and i'd get 6 quarts to be safe. you can buy a case from the dealer and it'll be cheaper that way.
  9. Jun 11, 2009 at 2:48 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Thanks man!
  10. Jun 11, 2009 at 2:39 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    My repair manual is showing that my transmission doesn't even take 2 qts. of tranny fluid. Does this sound right? Also, do I fill thru the dipstick tube?
  11. Jun 11, 2009 at 2:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the manual is wrong as far as that goes. and yep...thru the dipstick tube. you need a long transmission funnel....they work alot better than the other funnels.
  12. Jun 11, 2009 at 7:55 PM
    ChrisYoTaCoMa
    ChrisYoTaCoMa Chrome's for Harleys and old farts
    Estero, Floriduh
    00 Taco 4x4 Ex cab 2.7 sr5 AT
    New Pioneer stereo, and all 4 speakers with Infinity components. Sirius satellite radio. Deckplate mod done. Door buzzer silenced forever thank God, tinted windows, vent visors, hood protector(bug guard), ceramic pads and new rotors, dechromed EVERYTHING. 2" Lift front 3" rear. Skyjacker AAL's and replacement leafs(and front spacers) from Fatbobsgarage.com. Skyjacker 7000 Hydro rear shocks, those Bilstein 5100 fronts are coming soon!
    The manual is VERY wrong. My 2000 Taco owners manual says 2.1 quarts with drain and refill.... NOT. When I drained it it was a total of 5.5 quarts. I replaced the filter also, for $30, it is worth the investment.
  13. Jun 12, 2009 at 2:49 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    How the hell are all these different manuals wrong??? Very strange.
  14. Jun 12, 2009 at 3:43 AM
    ChrisYoTaCoMa
    Estero, Floriduh
    Crazy huh? I knew something wasn't right when I pulled the plug and it kept a comin' out. I have a big 11 quart pan and it was half full. So I took the pan down, did my filter, etc. Pured in the "2.1" quarts it said I needed. IT NEVER EVEN REGISTERED ON THE DIPSTICK. I added the rest of the 3rd quart, still nothing(yes I started it up to check). So I had to send my wife to the parts store for 3 more quarts. I added them 1 at a time until I hit the cold mark when idling. Checked it running hot, and it ended up 5.5 quarts I needed. SO, where does Toyota get this 2 quart stuff?
    You are right 2 different years, both wrong. How is this possible???
    + I have read on other websites the SAME thing with other people found the same issue.
  15. Jun 12, 2009 at 2:01 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Both my owners manual, and my Haynes repair guide show around 2 quarts for a drain and refill. Crazy. It will definitely take 5.5 quarts to do it, huh?
  16. Jun 12, 2009 at 2:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yes...thats why i recommend going ahead and getting at least 6 quarts.
