Transmission shifter base bolts: Those with URD short shifter, Help
Discussion in '4 Cylinder' started by jassco, Dec 26, 2011.
  1. Dec 26, 2011 at 8:30 PM
    jassco
    jassco [OP] Well-Known Member
    NH
    2023 TRD Offroad
    Long story short someone stole the tool bag containing the original 4 bolts from my transmission shifter base used before my urd shifter was installed. If you have done the URD short shifter install you probably still have these bolts as they are replaced by longer ones. If you didn't get rid of them I need them. I must go back in for warranty work and want to remove the plate(don't want hassle). PM me if you are willing to send them to me or if you are able to give me some specs as the the size and length/pitch that would be very helpful as well. For those of you still scratching their heads the pic of the bolt's location is below.
    Again this is for the R155F transmission which means 4x4, so I am unsure if the 2wd R155 has the same shifter base.
    Thank you
