Transmission shifting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sukhster, Jun 27, 2011.
  1. Jun 27, 2011 at 12:51 AM
    Sukhster
    Sukhster [OP] New Member
    Surrey BC
    2011 Toyota tacoma 4x4 Trd Sport
    Hi I have a 2011 Toyota Tacoma Trd sport long bed
    Every time I go down a hill from stop. My truck will not shift into the 5th gear until I am on a flat straight stretch. It will rev above 2000 rpm. Then when I hit a flat straight spot on the road it will shift into od. Also when I'm going down a hill I hit the brake pedal the truck will shift down a gear and upshift back when the hill is finished. Is this normal or should I get it checked out. Pls let me know thanks
  2. Jun 27, 2011 at 5:11 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    My truck behaves the same. I like it as it saves transmission wear shifting in and out of 5th on uphills and brake wear as well as reducing onset of fade going downhill.
  3. Jun 27, 2011 at 6:55 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Any time you hit the brake, the torque converter will unlock.
  4. Oct 29, 2013 at 7:41 PM
    ISwhatITis
    ISwhatITis Member
    Justin
    Arizona
    06 TRD OFFRoad 4x4
    KN Intake, JBA Headers, JBA Exhaust, 285/75/16 Nitto trails M/T, halo headlights, satoshi grill other minor mods
    Any resolution on this issue, i have an 06 4x4 automatic with the same issue
  5. Oct 29, 2013 at 7:47 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    King CO's Camburg UCA (to be installed) Alcan wheelers leaf pack (returned, will replace with allpro) Fox 2.0 rears Wheelers super bumps LightForce 170's
    I didn't think it was an issue? Isn't it just DAC?
    :confused:
  6. Oct 29, 2013 at 7:57 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Engine braking , not DAC and normal
  7. Oct 29, 2013 at 8:01 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    OP... It's called engine braking and is completly normal.
    DAC is for going down extreme angles while offroading and can only be used in 4L.
  8. Oct 29, 2013 at 8:10 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Cannot fix something that is not broken.
    All vehicles unlock convertors when the engine load is enough and downshift as well if the needed to due to hills or engine load.
    This is very apparent around 45-50 mph on most vehicles.
    As for downshift on decel all autos do this as well, some more apparent than others, higher geared vehicles it will be a bit more noticeable.
