Transmission shifts a little rough between 1st and 2nd a low speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09 TRD Sport Maui, Dec 19, 2016.
  1. Dec 19, 2016 at 10:30 PM
    09 TRD Sport Maui
    09 TRD Sport Maui [OP] Member
    I just purchased my first Tacoma! I bought a used 09 Tacoma sport pre runner with 83k. I love this truck,but the transmission shifts a little rough between 1st and 2nd gear at low speed almost like it lunges a little. I've changed the Fluid with Toyota WS and didn't help. I've read online that this is normal? I've also read There's a TSB on this O703-10 but those people transmission problems seemed a little more severe. Is there a way to fix this or do I have to just live with it????
  2. Dec 19, 2016 at 10:32 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Welcome to TW!
    Yes, the 1-2 shift is & always will be horrible. Other than getting a manual transmission, learn to live with this
  3. Dec 19, 2016 at 10:37 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Huh, never knew this was a problem, I have an 06 4.0 auto with 138k and my shifts are all very smooth.
    Might want to specify your transmission model #, or at least if your a 4.0litre or 2.7 and im assuming auto?
  4. Dec 19, 2016 at 10:40 PM
    09 TRD Sport Maui
    Thanks.
    So you don't believe the ECU re flash would fix this problem?
  5. Dec 19, 2016 at 10:41 PM
    09 TRD Sport Maui
    Yes 4.0 auto
  6. Dec 19, 2016 at 10:45 PM
    excorcist
    Reno, NV
  7. Dec 20, 2016 at 7:54 AM
    09 TRD Sport Maui
    Anyone else experience the noticeable 1-2 shift at low speed?
    Mattsyota529 likes this.
  8. Dec 24, 2016 at 4:58 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    On my "new-to-me" '09 4.0 DC the 1-2 upshift is at times (lower speeds as you describe) noticeable; not horrible or jarring, just noticeable. I have attributed this to the relatively wide gap between the 1st and 2nd gear ratios
    Here are the gear ratios for all 5 gears:
    • 1st: 3.52:1
    • 2nd: 2.04:1 (a 72.5% "higher" gear)
    • 3rd: 1.40:1 (45.7% "higher")
    • 4th: 1.00:1 (40.0% "higher")
    • 5th: 0.72:1 (38.9% "higher")
    You can see the ratio difference between 1st and second is 72.5%; that's a pretty big jump from a lower to higher gear. Combined with the engine's high torque at low rpms (see dyno chart below) and "largish" mass of the driveshaft, axle and wheels/tires it is inevitable that it will be noticed.
    Tacoma 4.0L:
    FWIW that is a pretty damned good looking torque curve for a V6...
    TnShooter likes this.
  9. Dec 24, 2016 at 5:07 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ^ JEZUS, never knew the v6's torque cuve was THAT flat. damn, no wonder why it feels like it has much more balls than my dads 3rd gen 3.5L at low to mid rpms.
    Also, yeah the 1st to 2nd shifts can be a little abrupt at times, especially when cold, no way around it but its FAR smoother than my old 2001 chevy... that thing would chirp the tires between first and second it shifted so hard.
  10. Dec 26, 2016 at 9:51 AM
    09 TRD Sport Maui
    Thanks, for the info it's just like you described more noticeable than anything. Seems like its normal and I don't need to bring it in. I was thinking of having Toyota reset the computer on the transmission,but I think I'll just let it be. I've had this truck about 3 months and I'm loving it!
  11. Dec 26, 2016 at 1:18 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    There is a 2009 TSB for a/t shifting issues Http://www.paladinmicro.com/images/Tacoma/TSB-0373-09.pdf--however it references the 2-1 downshift. This was performed on my '09 by the Toyota dealership from which I bought the truck (they made sure all TSBs an recalls/etc had been done), so I have no idea how it would drive without the update. The TSB makes no mention of the 1-2 upshift...
  12. Dec 26, 2016 at 3:38 PM
    09 TRD Sport Maui
    The 2-1 shift on my truck seems fine. The TSB I was reading about was 0703-10 I think this one was more related to the 1-2?
  13. Dec 26, 2016 at 3:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    There is an old transmission TSB for 09's for a lag or hard shift between 1st and 2nd , I had it done on my truck . I believe the tranny reflash was subsequently included with the brake override reflash so if your truck has had neither of those done that may solve it
  14. Dec 30, 2016 at 7:24 PM
    Eric J
    Eric J Well-Known Member
    Ponte Vedra Beach
    2008 MGM dcsb 4x4 Trd sport debadged
    To many to name
    Mine dose it
  15. Dec 30, 2016 at 7:24 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    Not bad tho
  16. Dec 31, 2016 at 7:19 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Mine can have a rough shift, especially when cold. These transmissions are very reliable though. Very few problems ever happen.
    TnShooter and Eric J like this.
  17. Dec 31, 2016 at 7:20 AM
    Eric J
    Ponte Vedra Beach
    To many to name
    Same^^
  18. Dec 31, 2016 at 9:30 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    Mine (05) shifts smooth. :notsure:
  19. Oct 2, 2018 at 4:59 AM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Thread revival!
    So I've noticed here in the past 2-3 weeks, I've been experiencing similar symptoms with my 2015 V6 Auto. Transmission is smooth as butter in 1,3,4,5 & is great from 5 all the way down to 1.
    I've noticed lately that on acceleration when the transmission shifts from 1st to 2nd there's an ever so slight hesitation, and then the first few RPM's of 2nd gear are slightly rough. It feels exactly like a manual transmission feels if you shift to a gear too early with that kind of seat vibration you feel in your butt. It's not jarring, doesn't rattle the whole truck, but it's noticeable to me. Happens most under light to moderate pedal, only in 2nd gear.
    Is it generally accepted that this is fairly normal on the 2nd Gen autos?
    Not sure if related but I did install a 3-Leaf AAL a few weeks back. I realized after the install that I forgot to re-install the factory angled shim between the bottom leaf and the axle. Took everything apart, re-installed with the bottom angled shim, and feel like that's when I noticed the 2nd gear roughness the most. Wonder if re-installing that shim with the AAL may have thrown some angles off? But like I said this only happens in 2nd.
  20. Mar 7, 2020 at 2:13 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    Revived again! Any updates on this condition and any fixes?
