Transmission Shot at 60K
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MDBigRed, May 7, 2012.
  1. May 7, 2012 at 1:47 PM
    MDBigRed
    MDBigRed [OP] Well-Known Member
    Potomac, MD
    '08 TRD Sport 4x4
    Uniden PC78Elite CB, 4' Firestiks, KC reverse/work lights, Mudflaps removed, Gorilla wheel locks, TRD box air intake, MBRP XP series dual exhaust, Wet Okole seat covers, 20% front tints, Pacer tailgate light bar, Uniden Bear Cat PA external speaker, 4.5" RCD Lift w/ extended ICON coilovers, door sill LED running lights, LED alarm scanner light, Scangauge II, Blendmount, Diff breather mod, Whelen hideaway 90watt strobes, Piaa Xtreme white bulbs, VIAIR onboard air, Allpro T-case sheild, TC LCA Skids, Stubbswelding HD-SKO Sliders, Weathertech floor mats, TC UCA's, Allpro SS brakelines, rear ARB locker, 4.56 Yukon gears, BlueSea fuse block, bed rail light bar, Shrockworks bumper, Smittybuilt XRC8 Comp winch, IPF 900's, Piaa 510's, Tekonsha brake controller, Air horn, Pop 'n lock, Alcan Spring leaf packs, JVC KD-AHD 69 head unit, 12voltguy winch controller, Safari Snorkel
    So for the past few months I've been having a transmission shudder when the truck is accelerating around 2000 rpm and the transmission shifts rough when downshifting at highway speed. This is the sure sign of a broken motor mount (99% of the time), so we pulled the motor mounts and they were both in good condition.
    Keep in mind I just replaced a U-joint and bad carrier bearing on my drive shaft a few weeks ago. Turns out the clutch packs are bad and when we pulled the pan on the tranny there were metal filings in the fluid. Needless to say the transmission has to get re-built or replaced with a re-built one. What's the pricetag? $4000 f-ing dollars. I'm sorry but 60K is an unacceptable lifespan for any transmission.
    Anyone else have their transmission go out this early? Regardless of the fact my truck is used as one, I still am having a hard time getting my head around this.
  2. May 7, 2012 at 1:51 PM
    Large
    Large Red
    Depending on the year, 60k is warranty work.
  3. May 7, 2012 at 2:31 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    My manual only made it to 30k. Advanced adapters makes an adapter to go from the 1GR to Chevy TH400. You won't break one of those, and they are considerably less expensive.
  4. May 7, 2012 at 4:21 PM
    MDBigRed
    Potomac, MD
    '08 TRD Sport 4x4
    Marlin Crawler has not come out with an option for the 2nd gens yet (to my knowledge). Are there any aftermarket upgrades I could purchase / install?
