Transmission Shudder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jmerritt804, Jan 10, 2023.
  1. Jan 10, 2023 at 11:18 PM
    Jmerritt804
    Jmerritt804 [OP] Member
    Hello, I have a 2009 Tacoma with a 4.0 V6 and an automatic transmission. I’m having a low RPM shifting issue I’ve drained the pan and refilled the transmission but it didn’t change anything. I checked the level after putting the truck in the temp check mode etc. The u-joints and suspension are new. If I give the truck more gas it will downshift and not shake but it seems like it’s the torque converter locking/unlocking. Any solutions for this? Thanks.
  2. Jan 11, 2023 at 3:28 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Drive it in 4th and see if it still shudders. If it doesn't then replace torque converter.
    Kolter45 and Ricardo13x like this.
  3. Jan 11, 2023 at 3:47 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Are you sure it's the transmission and not the engine missing?
  4. Jan 11, 2023 at 4:46 AM
    Jmerritt804
    If it was the engine missing then I would’ve thought that increasing the throttle would make it worse or throw a code perhaps. How can I determine if it’s the engine missing this bad? Sure feels like transmission. It seems to only happen during low RPM higher load situations. No shutter on the highway.
  5. Jan 11, 2023 at 4:48 AM
    Jmerritt804
    I’ll give it a try.
  6. Jan 11, 2023 at 7:11 AM
    cardigan
    cardigan Member
    2009 Tacoma DCLB TRD Sport
    I'd do a drain and fill again and add lubeguard. I have an 09 and after doing a couple drain and fills with lubeguard, my shutter went away almost completely.
    dolbytone likes this.
  7. Jan 11, 2023 at 7:16 AM
    Jmerritt804
    I want it completely gone. I saw a few posts about lubeguard so I’ll order some.
    cardigan[QUOTED] likes this.
  8. Jan 11, 2023 at 7:18 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    It’s OD Shudder. It’s common. One flush improved mine but I can still get it to happen if I try.
    I have a buddy that’s done 3 flushes and replaced the torque converter but his still has the issue. He is resigned to deal with it for now but thinks it may be an out of balance drive shaft. He’s basically starting over trying to figure it out. He drives a ‘13 TRD OR double cab.
    Kolter45 likes this.
  9. Jan 11, 2023 at 7:24 AM
    cardigan
    cardigan Member
    I was genuinely impressed and surprised at the difference lubeguard made, I'd say my truck is 99% better if not 100%. I was pretty thorough with how I did it though, first I did a drain and fill and drove around for a few days. Then I did another drain and fill and added lubeguard. I used the shudder fix (small red tube) but also a bottle of the regular ATF protectant. Highly highly recommend.
    Taco 422 and Jmerritt804[OP] like this.
  10. Jan 11, 2023 at 7:27 AM
    Jmerritt804
    Wow, that’s not what I wanted to hear. So I’m guessing the shift points have to be messed with or a new transmission if he’s done 3 flushes and a converter. I’ll drive it till the wheels fall off before I’m forced to buy a transmission.
  11. Jan 11, 2023 at 7:31 AM
    cardigan
    cardigan Member
    Plates on TC get glazed, sometimes to the point beyond fixing. This is why drain and fills are important!
  12. Jan 11, 2023 at 7:39 AM
    bryanh69
    bryanh69 Well-Known Member
    2015 MGM Toyota Tacoma TRD OR
    I replaced the torque converter and added lubeguard. I still get it when the trans is hot. I just put it in fourth and it goes away.
    ejl923 likes this.
  13. Jan 11, 2023 at 7:47 AM
    Jmerritt804
    Thanks for the update.
  14. Jan 11, 2023 at 9:23 AM
    MA_TACO
    Wesley Chapel, FL
    Where did you get the converter from?
  15. Jan 11, 2023 at 9:25 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    What kind of fluid you using...
  16. Jan 11, 2023 at 9:48 AM
    Jmerritt804
    WS Type Toyota ATF.
  17. Jan 11, 2023 at 9:50 AM
    MA_TACO
    Wesley Chapel, FL
    After I replaced my converter I went with Valvoline MaxLife synthetic ATF. Over 3000 miles on the new converter and not a single shudder.
  18. Jan 11, 2023 at 9:51 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    How many miles?
    What did the fluid look like when you changed it..
  19. Jan 11, 2023 at 9:52 AM
    Jmerritt804
    150k. It didn’t look or feel bad to be honest.
  20. Jan 11, 2023 at 9:52 AM
    Jmerritt804
    Toyota converter?
