Transmission shudder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mag16tac, Apr 18, 2010.
  1. Apr 3, 2013 at 7:41 PM
    #41
    BM07TacoTRDsport
    BM07TacoTRDsport New Member
    B-ry
    San Antonio
    07 PreRunner TRD Sport
    Update: So my shuddering got so bad that I could not drive around town with the tranny in OD. When I did drive around in OD a awful studdering/shuddering would happen around 30-55 and again 40-45 range. I had to drive with it in 4th and only shift to OD after I got on the highway, which worked great and completely eliminated the shudder but also very annoying. The 1st things I tried were 1) turning over the CSB (didn't work), 2) checking all U-joints and replaced one that I'm pretty sure wasn't even bad - didn't work, and 3) I did a drain and fill on the tranny and when I unbolted the over flow bolt at least a quart of fluid or more drained out. I bought the truck used about 4 months ago so at some point before me I guess it was over filled. I then unbolted the drain plug and refill plug, drained the tranny the rest of the way, and only had to add about 1.75 qts until tranny fluid rushed out of the overflow hole, which is about half of what came out. My shuddering has not happened at all in the last 3 days (300 miles). So keeping my fingers crossed this works and if so I'm planning to make the drain and fill part of my regular maintenance routine.
  2. Apr 3, 2013 at 7:49 PM
    #42
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i have all of this at about 41mph:mad:
  3. Apr 3, 2013 at 8:04 PM
    #43
    gearcruncher
    Canadain bumper technician
    Once again as these posts continue and continue . If the issue is transmission related , use Lubegaurd to fix the issue .
    I would not waste your time or my time posting this if it didnt work !
    Find out where you can get it and drop some into your transmission . If the issue is transmission related , this will fix the shudder .
    If this is another drive line issue , Lubeguard wont help
    http://www.lubegard.com/~/C-113/LUBEGARD+Platinum+Universal+ATF+Protectant
    Kolunatic likes this.
  4. Apr 12, 2013 at 8:32 AM
    #44
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    I just started getting this issue lately....i am a 09 with this exact thing. I am lifted 6" and on 37's and have been for a while and now suddenly this comes out of no where.
    This is exactly what you guys are describing. around 45ish with light partial throttle its like my truck is lugging and shuddering bad, but if i let off and then apply throttle again it clears up.
    I can get it to do it often.
    What has been the fix????
  5. Apr 12, 2013 at 8:48 AM
    #45
    brutalguyracing
    F.U> GUYZ
    broken mods
    :popcorn:
  6. Apr 12, 2013 at 8:51 AM
    #46
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    :popcorn:
  7. Apr 12, 2013 at 9:07 AM
    #47
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Cape Breton Island Nova Scotia
    09 Tacoma 4x4 TRD Off Road
    I believe we share the same tranny as the FJ Cruiser. The FJ tranny has a known flaw that has a shudder. My wifes FJ got the shudder and I can tell you what I felt was very much as you guys are describing here. We took it to the dealer who could not find a problem. We then took the tech on a drive and then it did it in spades. He was shocked that it wasnt found on the initial inspection. Anyways it was diagnosed as a bad tranny and it had to be replaced at the tune of 7 grand! (Geico insurance rocks :headbang:)
    A check of the FJ forums reveals this is a common thing so it scares me that our trannys are the same.
  8. Apr 12, 2013 at 9:17 AM
    #48
    93civEJ1
    09 DC TRD OR
    i pulled my fuses last night to reset everything. Also unbolted and reseated my carrier bearing. Neither had any help on the issue. Still did it this morning.
  9. Apr 12, 2013 at 9:24 AM
    #49
    93civEJ1
    09 DC TRD OR
    Also, for anyone that has this same issue, next time it does it can you look at your Tach and see at what point your RPM is? Mine just kinda sits in the same RPM with the throttle barely applied and will shudder if I keep that constant speed / RPM. If i mash the gas hard or let off, the shudder goes away.
  10. Apr 12, 2013 at 10:12 AM
    #50
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    A stall test will not check the lockup clutch.
  11. Apr 12, 2013 at 10:15 AM
    #51
    93civEJ1
    09 DC TRD OR
    Also most of our trans do not have a dipstick to check the trans fluid level, but only that plug with the hex on it.
  12. Apr 12, 2013 at 10:36 AM
    #52
    93civEJ1
    09 DC TRD OR
    I just got sent a 7 page PDF of
    T-SB-0096-09
    It mentions alot of what sounds like this issue, but it states it is for 2WD Tacomas. Anyone know if this same TSB applies to 4WD?
  13. Apr 12, 2013 at 11:19 AM
    #53
    93civEJ1
    09 DC TRD OR
    Just called my local dealer I got the truck from to mention another recall I had got in the mail that I never got done about the gas pedal. Of course, a dang woman answered. Anyone she had to go check with one of the service writers or something and came back and said yeah they could do that one, but also said there is another recall on my truck for a Wheel Sensor or something. I went ahead and scheduled this stuff and Im just gonna print out the TSB and take it with me when I go and be like fix this junk too!!!
  14. Apr 12, 2013 at 9:13 PM
    #54
    Chadillac
    Chadillac Active Member
    Tri-Cities, WA
    12 TRD OR
    I'm not sure what the fix is, but I plan on taking my truck in soon. My truck only has around 15k miles and it's progressively getting worse.
  15. Apr 13, 2013 at 1:56 PM
    #55
    93civEJ1
    09 DC TRD OR
    Id like to take mine in too, but I doubt they will do anything for me since I am modified. Its annoying though and not normal at all.
    Mine just started at 66,000 miles. Never had this issue before.
  16. Apr 14, 2013 at 8:14 AM
    #56
    93civEJ1
    09 DC TRD OR
    So you guys think if I were to buy a new torque convertor and install it, that my problem would resolve? I am tempted because this is getting annoying as hell.
  17. Apr 15, 2013 at 12:56 PM
    #57
    Fedz
    Fedz Well-Known Member
    Fady
    Everett, WA
    2013 Tacoma TRD OR DBL SB
    OME AAL,
    Before wasting your money , make sure it is not a drive line issue. I am picking up a new drive line today 2 piece and a double cardan after the carrier bearing. I will install and report back.
  18. Apr 15, 2013 at 1:18 PM
    #58
    93civEJ1
    09 DC TRD OR
    99.5% sure its not a drive line issue.
    Its def RPM and gear related. You can put the vehicle out of OD shift mode and in 4 or something and the issue does not happen.
  19. Apr 15, 2013 at 3:59 PM
    #59
    gearcruncher
    Hooking up a scanner and going for a drive is going to tell the technician what your truck is doing .
    With a quality scanner , you can command upshifts and downshifts while driving the vehicle . Clutch volume index and slip rates can be viewed while driving . You can command the torque converter to lock and unlock , you can check solenoids and force motors inside the transmission .
    Some shops offer a free test drive using a scanner .
  20. Apr 15, 2013 at 5:30 PM
    #60
    brutalguyracing
    F.U> GUYZ
    broken mods
    this.....truth
