Transmission shudders randomly, limp mode kicks in
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pickle Jeff, Aug 12, 2022.
  1. Aug 12, 2022 at 7:15 AM
    Pickle Jeff
    Pickle Jeff [OP] New Member
    Jeffrey
    2015 crew cab 4*4 TRD sport
    None
    Driving up and down and level roads a random shudder shows up like driving on the rumble strips . Was bad enough pulling a hill one time the exceleration got jerky at hesitant . Pulled over turned off vehicle went away . Then does it randomly . Trac off light is on as is check engine and maint required . Codes says 2 and 3 cylinder misfire and repeats ... Is this limp mode even though all runs great and shifts great after battery disconnect ? Ready to junk my truck 166000 miles
  2. Aug 12, 2022 at 7:18 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Diagnose the problem, may be super simple like fowled spark plugs or could be something like worn out fuel pump.
    Pickle Jeff[OP] likes this.
  3. Aug 12, 2022 at 7:24 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    The simplest and easiest thing to do would be to change the spark plugs. When is the last time the plugs were changed?
  4. Aug 12, 2022 at 10:29 AM
    Pickle Jeff
    Jeffrey
    None
    Yeah that's where I started . Bought new Bosch platinum s . Old plugs barely hade center electrode three ngk and three nippondensos . One coil pack was oil on the side , clean light oil and a tiny bit of dark oil . Does those coils above the plugs have oil in side ?
  5. Aug 12, 2022 at 10:47 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you have oil in the spark plug tubes your valve cover gaskets are leaking, also some people have had issues with running platinum plugs in the 4.0l.
    Having 3 NGK and 3 denso plugs means they were original, the stock plug for the 4.0 is copper Denso K20HR-U11.
    If the coil boots were soaked in oil they should be replaced but don't do that until you get your valve cover gaskets fixed.
  6. Aug 12, 2022 at 11:25 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Doesn't sound like you are in limp mode. That is a self preservation condition that disables certain features, like AC, and greatly reduces the speed you can drive. What are the codes for the two cylinders? I’ll speculate you need to replace those two ignition coils. 166K miles on a set of plugs is a-lot and explains why the center electrodes were worn down so much; that puts a strain on the coils. Hopefully, that’s the only damage you’ve done. If you hate replacing coils, get iridium plugs - that’s what I have. They’ll last 80-100K compared to 50K for copper plugs - Toyota recommends 30K but that is for the emissions warranty, the plugs should easily last 50K, but not 166K!
    Pickle Jeff[OP] and Key-Rei like this.
  7. Aug 12, 2022 at 11:35 AM
    dtaco10
    Dave
  8. Aug 12, 2022 at 11:38 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I thought that was exactly what limp mode is?
    As for OP, Toyota's DO NOT like Bosch parts, and the 4.0 does not like platinum electrodes.
    Get some NGK Iridium and call it a day there but don't unload the parts shotgun yet get your codes pulled and some diag done. Check your fluid levels colors and age.
    If your plugs had tripple the milage interval on them I suspect your trans fluid is equally neglected.
    Dm93 likes this.
  9. Aug 12, 2022 at 12:30 PM
    Pickle Jeff
    Jeffrey
    None
  10. Aug 12, 2022 at 12:35 PM
    Pickle Jeff
    Jeffrey
    None
    Soo no I don't neglect tranny did flush last year . Switched all plugs truck runs great at 85 mph to the Toyota dealership . The ran the codes and nothing shows up at all and truck ran great up hills at 85 and flats at 85 to 90 . No mis fires , no shudders . Gave me a great deal on a factory air filter and an alignment and tire rotation . Plugs are more work than draining and sucking and blowing tranny fluid . Plug swap took half hour from start to finish on cold engine . I'll post again If shudder reappears . Really appreciate the feed back . I did find a giant dent in the oil pan for the transmission so I might take apart replace filter etc
    Key-Rei likes this.
  11. Aug 12, 2022 at 3:20 PM
    Chuy
    Lakeside, CA
    Silver Taco
    I may have read his initial symptoms differently. He said the hesitating was random.
    Key-Rei[QUOTED] likes this.
