Transmission Shutter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NickRobertsoon, Feb 1, 2022.
  1. Feb 24, 2022 at 9:15 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    If that's the case then replacing the torque converter should take care of the issue. Like I said, I had the same problem and now its gone after the swap.
  2. Feb 24, 2022 at 9:19 AM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    I literally just went through all of this 2 weeks ago. Shudder in D then hit it into 4 and it went away and it only happened at 25 to 35mph and below 1500rpm. Took it to a local transmission shop and they said it needed a rebuild due to the torque converter and possibly solenoids. Had it done and $2700 later it shifts smooth again. They pretty much replaced most of the transmission components I believe. The good thing is the mechanic I originally took it to has a deal with the transmission shop and I got a discount on parts and labor.
  3. Feb 24, 2022 at 9:27 AM
    MA_TACO
    Wesley Chapel, FL
    Man I'd hate to say it but that tranny shop ripped you off. Unless you were having shifting problems along with the shudder then a rebuild would be warranted. I thought I needed a complete rebuild myself but after some research I decided to just do the converter for $199 and luckily that's all it needed.
    Squirt[QUOTED] likes this.
  4. Feb 24, 2022 at 9:32 AM
    Squirt
    Ben
    Maybe it didnt but I need my truck to stay reliable for me. I forgot to mention it would make a noticeable jerk and sometimes slight clunk when it would shift from O/D to 5th or 4th.
    Edit: I'm near 185k miles so it's not exactly new
  5. Mar 6, 2022 at 12:52 PM
    NickRobertsoon
    NickRobertsoon [OP] Member
    Nick
    2009 TRD Tacoma
    Got the converter replaced. $2400 cad. No issues. But now I gotta new issue. Truck won’t start.
  6. Mar 6, 2022 at 4:09 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Won't crank over or cranks over but doesn't start?
  7. Mar 6, 2022 at 4:32 PM
    MA_TACO
    Wesley Chapel, FL
    Take it back to whoever did the work. Probably a loose connection or they forgot to plug something in.
  8. Mar 6, 2022 at 5:59 PM
    NickRobertsoon
    Nick
    2009 TRD Tacoma
    Can’t even get it there if it won’t start
  9. Mar 6, 2022 at 6:00 PM
    NickRobertsoon
    Nick
    2009 TRD Tacoma
    Wont crank or it will sometimes crank. I’ve gone over everything that I can. In the middle of replacing the starter myself. What a shitty job
  10. Mar 6, 2022 at 8:13 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    call them and tell them to send a tow truck and fix it
  11. Mar 6, 2022 at 8:43 PM
    NickRobertsoon
    Nick
    2009 TRD Tacoma
    I put a new starter in and all seems to be working fine now.what a pain in the ass to do on these trucks by yourself though
  12. Mar 8, 2022 at 6:54 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    I went and bought a whole set of extensions, 3/8" and 1/2" with a slight indent at the connection, it allows for bending, made the process a whole lot easier...
    Converter, working fine?
  13. Mar 9, 2022 at 6:56 AM
    NickRobertsoon
    Nick
    2009 TRD Tacoma
    Converter is working perfectly fine. Super impressed with the shop just wish the temporary LubeGuard fixes would’ve worked. Yup I had the extensions. Ended up using 2 6” a 12” and a 3” extension to get the top bolt off the starter. The first starter I put in was bad out of the box too so bad to do the whole process 2 times. Oh well it is what it is. Learning lots!
  14. Mar 9, 2022 at 8:15 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    Yup, the upper bolt is not friendly, thus the bendable extension parade. Funny you went through two starters, I had the same experience and was not happy, the first one worked but went bad three days later.. Second time around was a whole lot faster.
  15. Mar 9, 2022 at 10:15 AM
    #35
    NickRobertsoon
    Nick
    2009 TRD Tacoma
    That’s hilarious. The first one worked fine but squealed every start up. Ended up putting a remanufactured one in and it’s nice and quiet. Time for a general inspection of the truck and then it’s road trip season
