Transmission shutter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Boo22Taco09, Aug 8, 2023.
  1. Aug 8, 2023 at 4:28 PM
    Boo22Taco09
    Boo22Taco09 [OP] New Member
    2009 Tacoma V6 4 door Prerunner
    Ok guys i just bought 2009 automatic 2 wheel drive Tacoma 180000 miles. I noticed a shutter at low speed when transmission shifts. At faster acceleration it not noticed. The flush of transmission at 100000 was not done by previous owner. Should i get the machine trans flush from Toyota or just change it myself correctly, or do nothing?
  2. Aug 8, 2023 at 11:06 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    I'd consider curtains, but if shutters are your thing I won't yuck on your yum.
    Search around the shudder is common and there have been a few functional solutions - additives, flushes, fluid/filter changes and swapping the torque converter.
    Boo22Taco09[OP] likes this.
  3. Aug 8, 2023 at 11:58 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Use the search function in top right to look for all the topic threads you are interested in but can be a long read as many years of info.
    Welcome.
    See:
    Transmission shudder | Tacoma World
    And yes you can get a full flush at the dealer and that does all the fluid because the pan holds like 2 quarts and the converter the rest (most).
    I did at 100k and now nearing 200k so will do again but not cheap but did help my shifting and torque converter lock up (more positive).
    Many opinions on the good or bad of a full flush and that is common on TW.
    We give opinions and what the result was then you have to decide your course of action.
    Boo22Taco09[OP] and GilbertOz like this.
  4. Aug 9, 2023 at 8:19 AM
    losolmalon
    losolmalon Member
    If you're comfortable with the process and have the necessary tools, you can change the transmission fluid yourself (as I did). The hardest part was to choose the right fluid type and quantity.
  5. Aug 9, 2023 at 6:26 PM
    Boo22Taco09
    Thank you guys. Sorry for my spelling issue I’m from Mississippi. i think I’ll just change it myself. Can’t see how putting new fluid in could cause the situation to be worse. Thanks again for your responses.
