Transmission slamming into drive or reverse. Shutter right after it shifts into second.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTaco9486, Apr 27, 2025 at 1:22 PM.
  1. Apr 27, 2025 at 1:22 PM
    BlueTaco9486
    BlueTaco9486 [OP] Well-Known Member
    Bunk
    2013 Blue Taco
    Factory Off Road Package
    My 2013 TRD off road is shuttering right as it shifts from 1st to 2nd gear. I’m also experiencing a slam when I shift it into reverse or drive when the vehicle is warmed up. I’m thinking torque converter but some folks have changed shifting solenoids as well. I’m just wondering if maybe because it’s only slamming when the vehicle is warm if that could be a tell that it’s something specific.
  2. Apr 28, 2025 at 12:12 PM
    YellowstoneSteve
    YellowstoneSteve Member
    2014 Tacoma TX Baja
    I know a number of years ago I had hard shifts in my 2014. Turns out there was a TSB for a reprogram from Toyota and it took care of the issue. Not sure if this is the same issue but worth you checking if your rig had that reprogram.
  3. Apr 29, 2025 at 6:22 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the fluid level first
    lowmower and Dm93 like this.
  4. Apr 29, 2025 at 9:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This!
  5. Apr 29, 2025 at 9:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which reminds me. If there was a transmission dip stick, that'd be such a quick check. ...
    Good thing I know someone who's done that "upgrade."
    lowmower likes this.
  6. Apr 29, 2025 at 10:44 AM
    lowmower
    lowmower Well-Known Member
    Benji
    2011 Pyrite Mica V6
    When my transmission was low on fluid it did similar things. When was the last time you changed the fluid?
