Transmission Slip
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cgutierr, Jul 1, 2010.
  1. Jul 1, 2010 at 7:34 PM
    cgutierr
    cgutierr [OP] Active Member
    I have a 2006 Tacoma Prerunner. A new problem just arose. Scenario: I will be driving at say 55-65 mph and have to brake suddenly and slow about 15 - 20 mph slower.....I-95 in south Florida. As soon as I reach that slower speed the transmission seems to slip out of gear...if I get right back on the gas the motor wll rev up and drop in gear. What do you think?
  2. Jul 1, 2010 at 7:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im gonna say its probably the drive by wire setup. may be worth a look tho to see how the fluid level is.
  3. Jul 1, 2010 at 7:43 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Probably totally normal. What you describe as a 'slip out of gear' is probably the transmission doing exactly what its supposed to do....downshift into a lower gear. Then, when you press on the gas...the rpm's will be higher because it downshifted previously and now needs to get back into the original gear it was already in before you put the brakes on.
  4. Jul 1, 2010 at 8:01 PM
    cgutierr
    Janster i hope your kidding!
  5. Jul 1, 2010 at 8:10 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    nope she's not kidding, that's the nature of the beast. your transmission tries to be smart and when you hit the breaks it downshifts to hold a lower gear for you, then when you get back on the gas it freaks and gets back into the original gear
    edit:: sorry :anonymous:
  6. Jul 1, 2010 at 8:12 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    All good now.
  7. Jul 1, 2010 at 8:14 PM
    cgutierr
    I have put 105,000 miles on this truck since its new. This is not a normal downshift. Did you ever take grandma's car for a joyride when you were a kid. Remember the old neutral drop. That is what it feels like. It has only begun the last 250 miles or so.
  8. Jul 1, 2010 at 8:19 PM
    cgutierr
    5000 miles ago... just a drain and fill.
  9. Jul 1, 2010 at 8:19 PM
    CopDoctor
    08 335i
    eh, then i'm wrong
  10. Jul 1, 2010 at 8:25 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Then it was done wrong. Bet you $20 the fluid level is too low.
  11. Jul 1, 2010 at 10:38 PM
    Janster
    Jandy
    Lancaster, PA
    Never took grandmas car for a joyride ....
    You should've given a better description to start off with.
    Why didn't you have the system flushed?
  12. Jul 2, 2010 at 9:35 AM
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
    My 2010 DC would have been a perfect car except for the dumb transmission (had the tsb done). When I slow down to go over a speed bump (under 10mph) and then get back on the gas, the engine just revs up but no response from the trans. It's much worst when the car is coasting (slightly down hill).
    And when trying to accelerate at around 50, it refuses to down shift even the gas pedal is almost to the floor. But this I had expected from Toyota trans, trying to use less gas.
  13. Jul 2, 2010 at 9:51 AM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    I had an 06 with similar symptoms, everyone said it was normal including the dealer. As it turns out the valve body was going out at 86k. I sold it and started over with a different truck. What I would do is take your ride back to the dealer and have them service the tranny again, but this time do a full flush. That should help some but i'm afraid your truck will never be the same again.
  14. Jul 2, 2010 at 12:11 PM
    JKD
    JKD Well-Known Member
    That sounds very abnormal. My transmission (09 V6 auto) downshifts just fine with throttle pressure at highway speeds.
  15. Jul 2, 2010 at 1:31 PM
    amati5
    2010 Prerunner TRD
    My old 94 Lexus SC400 did this too so I assume Toyota design their shifting points conservatively to save gas. I should at least check the oil level.
