transmission slippin? problems? AHHHHH
Discussion in 'Technical Chat' started by cwitters86, Aug 12, 2010.
  1. Aug 12, 2010 at 4:53 PM
    cwitters86
    cwitters86 [OP] Member
    seattle
    01 prerunner sr5
    The Ride: 01 prerunner v6 automatic tranny ext cab (NO 4x4) 155k miles on it
    The Problem: I bought the truck back in January this year, about 3 months ago i noticed the truck doesnt click in gear as well for reverse. Like it will naturally go backwords but when you accelerate it slips. Then, this last weekend it did it in drive. I went to accelerate and it jus rev'd up the rpms as if it was in neutral. I stop the truck put it in park then back in drive and all was fine, which hasnt happened again in drive. But now that i think about it, the truck has seem to have died down on the acceleration when i hit the gas, not even close to the power the v6 showed when i first bought the truck. Almost as if the trucks tranny has slipped and doesnt quit give out its full potential. What could it be? A friend suggested a tranny flush but i checked the oil and it wasn't so terrible to be causing this. Any answers? Thanks!
  2. Aug 12, 2010 at 6:42 PM
    747 function > form
    1st Gen.
    Change out fluid to B&M Trick Shift?:notsure: Worked on my Buick.
  3. Aug 12, 2010 at 9:27 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    in 155k miles how many times filter inside the tranny was changed if never, I would drop the tranny pan replace filter refill with Mobil ATF Synthethic and see what happens. Filter in the tranny is very often forgotten and no flush will remove dirt out of it.
  4. Aug 12, 2010 at 9:49 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    filter not enough pressure to keep it engaged would be my first assumption. drain, change filter, flush and refill.
  5. Aug 13, 2010 at 5:38 AM
    cwitters86
    seattle
    01 prerunner sr5
    changing the filter out hard to do?
  6. Aug 13, 2010 at 5:58 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
