Transmission Slipping After Swaping Out
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1999tacotrd, Jun 13, 2009.
  1. Jun 13, 2009 at 1:53 PM
    1999tacotrd
    1999tacotrd [OP] 1999 Taco TRD xtracab 3.4 V6 4x4
    Hi i bought a used transmission from the slavage yard for around $700 it was said to have 100k miles on it well we installed it and it works besides when i come to a hard stop at a stop sign it wont go it takes about 20 secs then kicks in and takes off! I have filled it with fluid and lucas transmission fix but still no good. Could it be it dose'nt have enough fuild begin it shows full? or a dirty filter cause i have'nt replaced it or did i throw away $700 on a POS transsion?
  2. Jun 13, 2009 at 2:55 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Sounds more like a torque converter issue, rather than transmission slippage.
  3. Jun 17, 2009 at 11:02 PM
    1999tacotrd
    I filled it up with lots of fluid way pass the full mark and it seems to be working now. i guess it didn't have enough fluid in it.
  4. Jun 17, 2009 at 11:25 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Or you have a pressure drop in the trans
  5. Jun 18, 2009 at 10:01 AM
    1999tacotrd
    pressure drop? what is that
  6. Jun 18, 2009 at 5:08 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Auto trans use pressure to work, if it has a bad seal somewhere inside it could cause slipping, more fluid could be building more pressure making up for a pressure leak in the trans but could maybe hurt something else down the line, but if it works then it works :D
  7. Jun 18, 2009 at 7:38 PM
    1999tacotrd
    Seal as in front and back seal or inside the transmission?
  8. Jun 18, 2009 at 8:25 PM
    dually
    dually Low and slow
    Internally, there arent any seals. All o-rings in the clutch pack actuating pistions. But that isnt the problem. If it was a pressure issue, it would be with the valvebody. Low fluid can definitely cause those issues!
  9. Jun 18, 2009 at 9:01 PM
    1999tacotrd
    phew ok so nothing to worry about. i know i put new front and rear seals in it before install to make sure they didn't start leaking again.
