Question about KDMAX 6.0
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoOnIce, Apr 22, 2021.
  1. Apr 22, 2021 at 9:53 PM
    TacoOnIce
    TacoOnIce [OP] Member
    2019 TRD Pro
    I'm running the KDMAX 6.0 87 octane regular throttle. There have been a couple of times now that I have let off the accelerator and then lightly stepped back on it only to have the RPM shoot up abruptly without a gear engaging. It feels like my truck is neutral when it happens. I've been able to recreate it a few times intentionally. It seems like if I let off the accelerator just as the gears are about to change and then reapply gas the transmission simply gets hung up. If anybody else has experienced this I'd like to know.
  2. Apr 23, 2021 at 1:40 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Don't have that issue. Tunes excellent for me. Hope you get it sorted out.
    TacoOnIce[OP] likes this.
  3. Apr 23, 2021 at 1:45 AM
    bolt_thrower77
    bolt_thrower77 Well-Known Member
    2021 DCLB trd or
    you should definitely post this to the kd max thread.....
    ranpack, whatstcp, Skydvrr and 6 others like this.
  4. Apr 23, 2021 at 2:20 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Only thing I can think is you caught the truck in the middle of a shift when you hit the gas the 2nd time
    Skydvrr and 71tattooguy like this.
  5. Apr 23, 2021 at 2:23 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Definitely talk to @PapaRee
    I'm not sure what changes there are, but if I had to assume, it's the torque based shifting map(s). You're likely crossing the threshold, causing a downshift and upshift by teetering on the line.
    This is all an assumption though.
  6. Apr 23, 2021 at 5:02 AM
    davet48732
    davet48732 Member
    Dave
    2019 TRD OR
    following
  7. Apr 23, 2021 at 5:13 AM
    The_vue's
    The_vue's Well-Known Member
    18 cement
    You notice this in slower speeds and only on cold start up?
    TacoOnIce[OP] and Technique like this.
  8. Apr 23, 2021 at 5:26 AM
    N5J_Taco
    N5J_Taco Well-Known Member
    Any time I've load a new tune things feel different so there is some settle in time especially if you reset AT/LV usually a tank or 2. The transmission learns all the time, changing files by changing shift points and throttle angles takes a while for the transmission to adjust to the changes. Give it some time it will work itself out, the more you drive it settles in faster. I have KDMAX 6.0 NO issues here!
  9. Apr 23, 2021 at 5:33 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Could be coincidence, you may unfortunately have other issues that popped up around the same time. I sure hope they still can't see tunes at the dealer, cause if detected, seems like any easy way out for them.
    I'm not anti tune, I'm intrigued, but also have these fears too.
  10. Apr 23, 2021 at 5:37 AM
    danwray
    danwray Traitor
    Dan
    Kentucky
    2021 Ford F150 XL 4x4 2.7 ecoboost
    Mine does the same thing stock, just feels like I caught the transmission logic off guard. Like it thought I was slowing down more, but I decided to speed up. Never worried about it
    gmtech, TacoOnIce[OP] and Amanelot like this.
  11. Apr 23, 2021 at 5:42 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Same
  12. Apr 23, 2021 at 5:43 AM
    hikeril
    hikeril Member
    I have a 2020 stock. Mine did the same about a month ago, 30k miles. Dealer going to check it over next week. Low pressure fuel pump is being replaced so I mentioned it to the dealer. I was also slowing down Then pressed on the accelerator.
  13. Apr 23, 2021 at 5:58 AM
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    This can happen on any tune within the first few tanks after flashing as the ECU re-learns to adapt to its new parameters. I would give it 2-3 tanks of gas to settle out before worrying about it.
    TacoOnIce[OP], Tacolife5 and tclavell like this.
  14. Apr 23, 2021 at 8:21 AM
    TacoOnIce
    2019 TRD Pro
    That's what seems to be happening. The odd thing is that the gear doesn't engage until I let off the gas and reapply it.
  15. Apr 23, 2021 at 8:22 AM
    TacoOnIce
    2019 TRD Pro
    It's happened doing 75 down the highway after an hour of driving and also in a parking lot right after starting it.
  16. Apr 23, 2021 at 8:24 AM
    TacoOnIce
    2019 TRD Pro
    I may give it a little longer but I probably have about 400 miles on it now.
  17. Apr 23, 2021 at 8:27 AM
    TacoOnIce
    2019 TRD Pro
    Strange. Mine never did this before. I may flash back to stock and see if it still happens. If so I'll have to take it to the dealer because it definitely shouldn't do that in my opinion. Do you by any chance also have deceleration vibes?
  18. Apr 23, 2021 at 8:43 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Are you u giving it a little more gas, the truck downshifts, u let off, then get back in the gas and then it seems like it's in neutral? Honestly I think that's normal. The truck is deciding what gear to go into. "should i still downshift, or upshift". Almost like a rev hang.
  19. Apr 23, 2021 at 8:45 AM
    TacoOnIce
    2019 TRD Pro
    It definitely never happened before tuning.
  20. Apr 23, 2021 at 8:49 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Is that the sequence of events? Your driving style may be different than what the tune is expecting now that it's changed.
