Transmission slipping when cold and after reverse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cgalloni, Jan 4, 2016.
  1. Jan 9, 2016 at 12:56 PM
    mike2810
    mike2810 Well-Known Member
    Arizona - Rim Country
    had 06 Sport 4x4 , now 2016 Nissan Pro 4x
    How about telling the service manager that if its full, then you will pay for the check. If it is not full, they pick up the tab. Also you want to be present with the tech when they do the check.
    I took this approach with a different vehicle (not a Toyota) and it worked. I didn't have to pay.
  2. Jan 9, 2016 at 3:19 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Trans fluid was checked at 10K by the local dealer as part of maintenance (did not know that they would do the fluid ck as part of maint). Transmission was 5/8 qt. low.
  3. Jan 9, 2016 at 4:03 PM
    DRosales901
    DRosales901 Well-Known Member
    Dante
    2016 Silver Tacoma TRD OR Double cab 4x4 auto
    Took my truck in for 5k mile service. Asked them to check trans fluid. They said it was a pita but still did it and found the fluid to not be low. I had a busy day that day so I couldn't wait around and see them do it with my own eyes. I'm switching dealers for service though because there is one closer to my house and will request that this dealer check the fluid at 10k miles.
  4. Jan 9, 2016 at 7:07 PM
    JKrammes
    JKrammes Active Member
    Jeremy
    Pa
    So I can't check the T fluid myself?
  5. Jan 9, 2016 at 7:15 PM
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    2016 Blk TRD Sport 4X4 DCSB
    Cracked W/S
  6. Jan 9, 2016 at 9:29 PM
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    I also have this issue - TRD OR DCSB With tow package... This is NOT a warm up issue, and should NOT be considered normal or acceptable. Chances are Toyota will deal with this by informing dealers to "top off" transmission fluid at a service interval. Keep in mind we are early adopters to this generation power train... Pretty annoying given that it's not advisable to run a tranny at low fluid levels.
    Wondering if anyone knows the exact type of tranny fluid used from factory...? Rant over.
  7. Jan 10, 2016 at 4:01 AM
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    Toyota WS ATF
    0uTkAsT likes this.
  8. Jan 10, 2016 at 4:28 AM
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    Idling in your driveway isn't going to warm the transmission. You need parts moving for that.
  9. Jan 10, 2016 at 9:48 AM
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    Not trying to be a know it all but, the 3 gen without tow package has a transmission fluid heat exchanger to bring the temp up.
    It's a different animal.
    BOTT likes this.
  10. Jan 10, 2016 at 4:11 PM
    cgalloni
    cgalloni [OP] Well-Known Member
    did it make a difference once the top the fluid? or is still having the same issue?
  11. Jan 10, 2016 at 5:26 PM
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    My Ranger had one and it never got the transmission up to full temp. I think it would get up to maybe 135 and it always took another few minutes of moving to actually get up to temp. I would putt around in the Ranger off road until it was up to temp. Then once it was up to temp I'd take off.
  12. Jan 11, 2016 at 3:46 AM
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    I never said there was no benefit to letting the engine warm up, just that idling in your driveway won't warm the transmission to full temp. My Ranger never got above 135 unless I actually started driving it. The only way you're engine and exhaust is going to produce enough radiant heat to warm the transmission to full operating temps is on the transaxle design with everything so tightly packed on top of each other. On a front engine, rear wheel drive design you typically have too much open space between parts to get it to full operating temps just from idling.
    I specifically had a temp gauge in my prerunner Ranger just to make sure I wasn't overheating it 100+ miles from camp.
  13. Jan 11, 2016 at 4:30 AM
    cgalloni
    I'm taking the truck again to the dealer this week. The transmission is slipping more and it seems is not getting better. Willing to be the technicians did not check the fluid last time i took it even though they say the did. This is not normal and even if i have to contact Toyota directly I will. no matter what other people say this is not normal for a transmission
    Hellapeno, Mr. Torgue and MannyS like this.
  14. Jan 11, 2016 at 5:01 AM
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    Cracked W/S
    If it's getting worse, then you probably do have some sort of problem. There's always a chance they didn't service it the first time, or even took to much out. Good luck, keep us posted.
  15. Jan 11, 2016 at 5:21 AM
    #35
    cgalloni
    before it only did it once i backed from my driveway and put in Drive, now is doing it without even backing . Turn on the car and put in Drive and that damn delay is there and then you hear the gear going in, after that is works perfectly but this is driving me crazy. Im waiting for the Service manager to contact me so i can talk to him about this issue . I will also be reporting this to Toyota directly
  16. Jan 13, 2016 at 2:53 PM
    #36
    sundogbrew
    sundogbrew Well-Known Member
    Joe
    2016 Blue TRD OR Double Cab
  17. Jan 13, 2016 at 7:16 PM
    #37
    crankb8tr
    crankb8tr Member
    Is this a result of "Hill Start Assist Control"? My 2016 with 2300 miles has a very quiet little bump that is only noticed when cold when shifting from r to d.
  18. Jan 13, 2016 at 7:53 PM
    #38
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
  19. Jan 14, 2016 at 1:30 AM
    #39
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
  20. Jan 14, 2016 at 6:26 AM
    #40
    sundogbrew
    Joe
    Someone told me it was an A760F and when I googled that I got some info about that being in the tundra. Not saying my info is right, more asking. So what is the transmission that is in the 3rd gen?
