Transmission Slipping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by randyg123, Dec 13, 2012.
  1. Dec 13, 2012 at 8:16 AM
    randyg123
    randyg123 [OP] Well-Known Member
    Randy
    2024 Bronze LTD
    I'm experiencing a weird slip in my autotranny. (2008 Off-Road Dbl Cab, 67k). Several weeks ago, I was sitting in a left turn lane when my truck lurched forward. The jerk was so hard it made a tire squeal and I thought I was hit from behind. (In retrospect I think I was just taking my foot off the brake and starting to accelerate). No-one was behind me so then I thought a passing vehcle clipped me and continued on. I pulled over and checked out my truck and found no damage. So then I was thinking I just must have had a brain fart and for some reason had my truck in neutral and shifted it into D just as I accelerated. But this 'jerk' has happened several times since then so now I know it wasn't me. It even happened as I approached an intersection trying to beat a light that was going to turn red. I came in fast, braked hard, and made a right turn. In the middle of the turn (when I stepped on the gas) the same thing happened. It's like the tranny downshifts but then goes into neutral before going into a lower gear. I called the dealership and the service guy there said he has had this issue before. Has anyone else experienced this?
  2. Dec 13, 2012 at 8:31 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    It may be a shift solenoid for first gear or second gear. Easiest thing to do is disconnect negative battery terminal overnight to see if its something that can be reset. Just take it wasy on your truck for a while and don't launch from a stop.
  3. Dec 13, 2012 at 8:32 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I was getting a very strange shudder at the about 38mph going up hills, just before the point where the trunk wanted to downshift. I thought it was carrier bearing or drive shaft related. I took it to Toyota, they ran it through all sorts of tests, even took out the drive shaft and drove it in 4WD (then front-wheel drive), could duplicate the issue.
    They didn't know what the problem was, were suspecting the torque converter but weren't convinced that was the issue. They went through the procedure for checking tranny fluid level, I guess found it to be a tad low. They topped it off and it hasn't happened since.
    Thought I'd share, sounds like a worth while option to explore the tranny fluid level maybe?
  4. Dec 13, 2012 at 11:06 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A lot of guys are having a lugging issue around that speed in OD. Checking the fluid level on these transmissions is no easy task, but definately worth doing.
  5. Dec 13, 2012 at 11:52 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    these trannies are so sensitive to fluid level. if off by a little they will shifty funny.
  6. Dec 14, 2012 at 6:17 AM
    randyg123
    Randy
    2024 Bronze LTD
    I left out (on purpose) that I just had the dealer flush the tranny about three weeks ago. I would assume it is related to that event. I'm curious what they will say since there was a 30-day warranty on the service. My guess was that they flushed some particles into a valve somewhere. But the fluid level could be off too based on what the previous posts have said. I'm sure their first response will be something that will cost me >$500. And then after I bitch it will probably be, "Oh the fluid was a tad low, no charge". :rolleyes:
  7. Dec 14, 2012 at 6:20 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    I'm guessing 08's are the same as 09 but did you have the recall/TSB done? It solves the cornering/downshift issue.
  8. Dec 14, 2012 at 7:29 AM
    BamaToy1997
    Bill
    Navarre, FL
    You have perfectly described what will happen in these, and other, automatic transmissions when the fluid level gets low. Tacoma trucks are very sensitive about fluid level.
    Sounds like you had a similar fluid level condition, however the Tacoma also has a history of trouble with one of the solenoids causing a shudder condition at speed.
    I would def take it back to dealer and ask them to check the fluid level. Let them know what has happened since the service was done.
  9. Dec 15, 2012 at 7:01 AM
    randyg123
    Randy
    2024 Bronze LTD
    Here is what the dealer said. The rear drive shaft is building up tension. The tension is released at the moment between deceleration and acceleration. There is nothing that can be done about it because there is no way to lubricate the drive shaft on the Taco. They said this is an occasional issue with Tundras and FJs but never have seen on a Taco. I am going to request they check my tranny fluid level before releasing it back to me if they did not do that already.
  10. Dec 15, 2012 at 7:08 AM
    randyg123
    Randy
    2024 Bronze LTD
    Quick update, I called about the fluid and they said that was their first thought too and they did check it. I didn't know they had to use a scanner to do this. Sounded like a rather complicated issue since the tranny is sealed.
  11. Dec 15, 2012 at 8:28 AM
    randyg123
    Randy
    2024 Bronze LTD
    Picked up the truck and talked to a service tech. He said it was a known problem and Toyota has issued service bulletins on it. It comes down to the non-serviceable slip joint they put in the rear driveshaft.
    My service rep gave me the number for Toyota USA to file a complaint and basically said that since my power-train warranty expired 7000 miles ago (what are the odds of that?), I will have to ask them to extend it. I had to do this with a spiral cable on a 94 Camry and they came through, just a lot of hoop jumping.
  12. Dec 15, 2012 at 10:18 AM
    BamaToy1997
    Bill
    Navarre, FL
    A lot of the "bumping" can be reduced or eliminated the same way we did it with the Chevy trucks that had the exact same problem.
    Remove driveshaft and clean splines.
    Clean splines on output shaft of transmission or transfer case (depending on 2WD or 4WD)
    Apply a VERY liberal amount of RTV silicone to the inside of the driveshaft slip yoke, ensuring that it is coating all of the splines for a good 2 inches deep.
    Reinstall driveshaft and allow truck to sit for a minimum of 2 hours, preferably 4.
    RTV silicone will fill the tiny gaps in the splines between the output shaft and the driveshaft, and will cushion the bump. Sometimes you will totally eliminate the bump, other times it will reduce it to acceptable levels. The good news is that you did nothing that would void your warranty.
  13. Dec 15, 2012 at 11:54 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Another possibility is it's the "axle wrap thump" these trucks get when the leaf springs get loose. Torque the U-bolts to 73 lbs and see if that helps.
  14. Dec 15, 2012 at 1:02 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    You can pull apart the driveshaft slip yoke and grease.
    Had the same problem with mine and it solved the issue.
    Search and you will see a thread I made on the issue.
    There is a clamp and a rubber boot you have to take off, not hard. About 30-45 minutes.
    It is supposed to be non serviceable but can be so you do not get bent over dry by toyota for a new driveshaft.
  15. Dec 15, 2012 at 8:25 PM
    BamaToy1997
    Bill
    Navarre, FL
    I like the RTV over lubricating. If you lube it, you eventually have to relube. The RTV is a long term fix. No lubrication ever needed again. Just an opinion mind you. Lubing still works.
  16. Dec 16, 2012 at 7:20 AM
    randyg123
    Randy
    2024 Bronze LTD
    I saw this described in the 2005+ Toyota Service manual posted online. I am surprised that the dealer didn't do this quick fix just to shut me up. But they seemed to think that this will be covered by Toyota and they will get the warranty work and make some $$ anyways. Right now, I do not want to get into any repair work to void any shot at warranty work. It sounds like they altered the Tundra and FJ to fix this problem so perhaps working on one for the Taco. Thanks for the advice; will keep in mind if this doesn't pan out.
  17. Dec 16, 2012 at 7:22 AM
    randyg123
    Randy
    2024 Bronze LTD
    Based on your animated GIF, I understand your affinity for silicone :D
  18. Dec 16, 2012 at 2:05 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    I am not sure what manual you are referring to but this is not supposed to be a serviceable part of the driveshaft so a tech will not typically service it. They will state to purchase a new driveshaft.
    This has been a problem since 05. Toyota is not fixing this. They do not even have a zerk fitting to add grease. They do not care.
    Almost all makers of trucks have a slip joint of some form which will eventually need maintenance or replacement. Some have had the shaft replaced under warranty but this is rare. Most are told this is typical and to live with it. Some have tried replacing rear leafs as well to reduce the effects it places on the shaft as well with less than favorable results.
    The driveline angles are off on most if not all Tacoma's that are brand new and have vibes or shudders depending on if people notice them or not. They are not doing anything to solve this either.
    There is a front end vibe from an out of tolerance bushing. Toyota looks the other way. Complain enough they will replace it with the same out of spec part, just stupidity.
    It is cheaper for them to try and refuse service and to replace parts for those that complain enough rather than redesign, recall or validate a problem via TSB.
  19. Dec 16, 2012 at 2:17 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Sounds like axle wrap or the u bolts aren't torqued to spec. When this happened as you described in the first sentence, had you come up to that light fast and braked hard?
    edit... also, i've read of some transmissions needing to get a re-flash because of weird shifts while cornering. Have you had that re-flash done that was part of the gas pedal cutting recall?
  20. Dec 17, 2012 at 12:29 PM
    randyg123
    Randy
    2024 Bronze LTD
    Service tech says it's, "wrap up" which I assumed is the same thing as axle wrap. I believe the tranny flash was done when the pedal was done.
