Transmission slipping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by czwhat, Dec 18, 2013.
  1. Dec 18, 2013 at 1:29 PM
    czwhat
    czwhat [OP] Member
    My 2010 taco with 72k is now slipping from 4th to 5th gear while driving. Dealer says needs new tranny at 4700 bucks. I wanted to see if anyone knows of a place that rebuilds toyota transmissions? I still find it hard to believe that a toyota would give out this early in its life an really don't feel like paying the steeler ship to do the work. Im most likely going to drive it a little more before fixing it but trying to find a different solution. Thanks
  2. Dec 18, 2013 at 1:49 PM
    czwhat
    czwhat [OP] Member
    I'm just disappointed especially after I just paid the truck off
  3. Dec 18, 2013 at 1:56 PM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    Did u check the trans fluid
  4. Dec 18, 2013 at 2:02 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Have you done a fluid replacement. There is a procedure post here that explains removing one of the cooler lines and flushing out the old stuff.
    Also, there is a person hear by the name gearhead that is pretty knowledgeable about these trans.
    I don't know all the ins and outs or failures, but there is a lot of talk about worn and leaky valve bodies. There is a repair kit for this.
    Also, there is a company that might be cheaper that builds these as high performance transmissions and might be a less expensive alternative for a better trans.
    PK
  5. Dec 18, 2013 at 2:04 PM
    Offduty
    Offduty Member
    Gary
    Colorado
    2014 DCSB TRD Off Road MGM
    Vent Visors, N-Fab Light Bar, KC Lights, Tonnaeu Cover, N-Fab Nerf Bars
    Have you serviced the trans in the past? That seems to be a lot of miles without replacing the fluid. The fluid in an automatic gets very hot and there is a lot of friction the oil goes through.
  6. Dec 18, 2013 at 2:05 PM
    xtyfighterx
    Ty
    I bought a dodge desiel from a guy who claimed the trans took a dump and when I got home and checked the trans fluild it was dry I put fluid in and it worked like new so check that before anything
  7. Dec 18, 2013 at 2:10 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
  8. Dec 18, 2013 at 2:15 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  9. Dec 18, 2013 at 5:31 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    If I have done a flush recently and the temp wasn't up u could ave too much fluid. I check mine the other day and it was pooring out after it warmed up. its much better now and had the me issue before hand.
  10. Dec 18, 2013 at 5:40 PM
    Esmi
    Esmi Member
    San Luis Obispo
    2013 Access Cab TRD Off Road4x4
    X2. I bought a dump truck that was "broken" and would not lift until I took it home and filled the hydraulic reservoir. Worth checking!
  11. Dec 18, 2013 at 6:30 PM
    gearcruncher
    Canadain bumper technician
    There are many things that need to be diagnosed properly within the transmission . How did the dealership determine you need a new transmission ? Did they pressure test the transmission ?
    in my opinion , it may be worth a try to get an aftermarket trans shop to have a peek at the valve body . There are a lot of fixes for the issue you are describing
    And $4700 better be a brand new trans , not rebuilt .
    I have been adding issues to my post . May be some info here you can use to fix your trans : http://www.tacomaworld.com/forum/te...hift-kit-shift-recalibration-kit-2nd-gen.html
  12. Dec 18, 2013 at 6:34 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    He is supercharged so it has seen more torque and HP go through it that most on here.
  13. Dec 18, 2013 at 6:40 PM
    wildcats
    wildcats Well-Known Member
    13 DCSB Sport
    You can a new ipt transmission for $3800, but that's without install. Don't know exactly how that works, if that includes a core deposit.
  14. Dec 18, 2013 at 9:13 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Again... this vvv
    Trust me. after my S/C install the shifts were sluggish as well.
    IPT upgrade solves everything. The stock valve body just cant handle the power and torque. The tranny is made for comfort.. so slow, easy, smooth shifts.
  15. Dec 18, 2013 at 10:39 PM
    gearcruncher
    Is IPT really your only choice ?
    From what I can tell , IPT uses the Gill Younger shift kit (TRANS-GO ) to firm up the shifts / boost pressure . Its not that difficult to make the trans shift more aggresive , its a matter of firming up the accumulators ( shift cushions )
    If I could get my hands on a valve body , i would be glad to install a recal kit at the trans .Shouldnt cost more than $200 bucks plus labor . Ive been installing them for a long time but never yet on the A750.
    A trans-go shift kit plus the added Sonnax boost valves would make a very solid transmission . Then decide what you prefer on the stall stage of the torque converter to match the torque curve of the engine you have .
    All i need is a valve body . Who wants to be a gineau pig ? :D
  16. Dec 19, 2013 at 5:08 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    As far as I know, and could find, IPT was it.
    Interested on what you could come up with tho. No spare valve body's here.
  17. Dec 19, 2013 at 12:55 PM
    czwhat
    czwhat [OP] Member
    I changed the fluid last month when I first started noticing the problem. Dealer told me that they checked the fluid level and it was good and that they confirmed that the tranny was slipping when shifting from 4th to 5th gear. Also that the only way to correct is a r&r it. I was hoping that maybe only would have to replace the torque converter.
  18. Dec 19, 2013 at 3:13 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    It's not the converter.
  19. Dec 19, 2013 at 4:05 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    or a used tranny from a totaled taco
  20. Dec 20, 2013 at 6:55 PM
    Ghostrider01
    Ghostrider01 Well-Known Member
    My 13 has 10k miles on it and I notice that when I'm getting on it about 2/3 or 3/4 throttle that sometime the tranny slips for just a sec between 4 and 5 th, I hear the rpms jump for just a half second. I kind found it odd. This post has me wondering. Thanks for posting.
