transmission slipping
Discussion in '3rd Gen. Tacomas (2016-2023)' started by howie51, Aug 27, 2016.
  1. Aug 27, 2016 at 6:03 PM
    howie51
    howie51 [OP] Member
    howard
    2016 tacoma trd or ext silver
    my tranny slips when it shifts into fourth gear when the fluid is cold first drive of the day fluid has been checked and the shift recall has been done anybody else having this type of problem thanks
  2. Aug 27, 2016 at 6:06 PM
    sadmrhappy
    sadmrhappy <insert clever title>
    cylinder 0, head 0, sector 1
    2016 Inferno Tacoma DCSB TRD Sport 4x4
    Did they do the manual process for checking, or just use techstream? The manual process takes a couple of hours because the transmission has to cool down and be warmed up to a specific temp range. If they didn't take a couple of hours, or keep it overnight they didn't really check it properly.
  3. Aug 27, 2016 at 6:21 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Yes it's probably the shift flare you're experiencing @bradwhitenikki has this issue I believe. He's been very vocal about trying to get it resolved. There are a handful of folks here reporting shift flare even after the software update TSB for the transmission. Mine seems to shift flare between 2nd and 3rd gear. only does it once and it's always in the first Drive of the morning
  4. Aug 27, 2016 at 6:42 PM
    smitty99
    Scottsdale
    Went to Face to Face concert last night. Been hurting all day....tied one on pretty good. Met with a bunch of college buddies some of them I hadn't seen in 10 to 15 years
    Biblite, rplusplus, dutchjim and 3 others like this.
  5. Aug 27, 2016 at 6:46 PM
    smitty99
    Scottsdale
    Now I'm getting the grill going to cook up some red snapper and make fish tacos
    Gander, Kilokato and DesertTaco4x4 like this.
  6. Aug 27, 2016 at 7:03 PM
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    howie, is this in your 2006?
    tomwil likes this.
  7. Aug 27, 2016 at 7:05 PM
    bradwhitenikki
    Brad
    Most use the Techstream, but that method is NOT accurate, and the Aisin transmissions are very picky about tranny fluid levels.
    smitty99 likes this.
  8. Aug 27, 2016 at 7:07 PM
    bradwhitenikki
    Brad
    I have this problem in my 2016 Trd off road. It is a valve body problem.
  9. Aug 27, 2016 at 7:12 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    And another thing.....(damn-it)
    When I'm going downhill at about 40 mph and apply the brakes a little for a curve the transmission now wants to down shift to about 3rd gear every time instead...
    I have to either select shift it back into a higher gear or hit the accelerator a little to get it back to the proper gear...
    I want slow a bit and continue coasting, NOT gear down...Very annoying
    Edit: Another post TSB issue.
  10. Aug 27, 2016 at 7:14 PM
    bradwhitenikki
    Brad
    Is this occuring in ECT or normal mode?
  11. Aug 27, 2016 at 7:15 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    Normal....I don't hardly use ECT....
  12. Aug 27, 2016 at 7:17 PM
    bradwhitenikki
    Brad
    This may be an engine braking strategy. My Honda does this. I will try and see if mine does the same thing. I find it annoying as well.
    Kilokato likes this.
  13. Aug 27, 2016 at 7:45 PM
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    What's a valve body problem? Is this like a cracked valve body? What material are these valves made out of? Just curious.. I work with larger valves in my day job sometime and curious about what kind of valves are used in a tranny.
  14. Aug 27, 2016 at 7:58 PM
    bradwhitenikki
    Brad
    The valve body is the hydraulic control system of the shifting in your transmission.
    Check out these links for a primer.
    https://en.m.wikipedia.org/wiki/Automatic_transmission
    https://m.youtube.com/watch?v=Du5X7LcVX5c
    http://www.sonnax.com/articles/209-aw-55-50-af23-33-diagnosis-and-valve-body-information
  15. Aug 27, 2016 at 8:11 PM
    bradwhitenikki
    Brad
    With the valve body being a pressurized fluid control system, any leak down of pressure, causing improper actuation, or release, of the actuator and brake clutches, of the planetary and ring gears, is a functional failure.
  16. Aug 27, 2016 at 8:24 PM
    david3821
    david3821 Well-Known Member
    2016 Silver Tacoma TRD Off Road
    I've had the same problems in my TRD OR. I had a shudder/slip feeling while accelerating into 4th and 5th gears. Doesn't happen in ECT as the rpm's are higher. So far I've heard that's it's valves in the tranny, torque converter shudder, or due to the rear gearing.
    I took the negative off the battery for an hour or two in an attempt to reset the tranny learn mode. When I attached again I drove the truck much more aggressively than I typically do. Could be placebo but it seems to be shifting better and my MPG has gone up from 20.5 to 22.5.
  17. Aug 27, 2016 at 8:31 PM
    bradwhitenikki
    Brad
    For anyone having this flair problem, it is a very wise idea to call Toyota customer service (tel:800-331-4331) and let them open a case on your vehicle. This will protect you if your transmission fails in the future. Toyota is very well aware of the problem.
    cosjohn likes this.
  18. Aug 27, 2016 at 9:12 PM
    smitty99
    Scottsdale
    What makes you say they're aware? What dialogue have you had with Toyota officials that leads you to believe they're aware
  19. Aug 27, 2016 at 9:20 PM
    bradwhitenikki
    Brad
    One of the supervisors, at the customer experience center, told me. He didn't say what part of the transmission was the issue. He just said there were known transmission problems with the 2016 AC60X transmissions. It was a Toyota service man, and 2 other well respected transmission repair guys (one a Toyota employee, and the other is on this forum), that pointed to valve body leak down as the cause of the flairs like I am experiencing.
    smitty99[QUOTED] likes this.
  20. Aug 27, 2016 at 9:23 PM
    Manvan
    Manvan Well-Known Member
    Paul
    2016 SR5 double cab
    It does not.
