transmission "slips" on steep uphill starts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by franzofthevalley, Sep 16, 2009.
  1. Sep 16, 2009 at 3:17 PM
    franzofthevalley
    franzofthevalley [OP] New Member
    California
    2009 SR5 V6 TRD 4x4 a/t
    Hi -
    I have a new Tacoma 4x4 SR5 v6 a/t. 8000 miles on it now. I have a job site where I enter thru a gate onto a steep uphill. I have to stop and get out to shut the gate. I put the truck in park, set the e-brake, shut the gate, put the shifter in D position, release the e-brake and try to start up the hill. I hear sort of a chattering sound, and the truck won't move forward. Anyone come accross this? Am I doing something wrong? Should I be doing uphill starts in a different shifter position?
  2. Sep 16, 2009 at 3:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    Your fluid could be more tward the rear of the tranny, or draining out of the converter when on the grade. Try this. After you put it in Drive, give it a second before taking off....See if that does anything. Then, you may have to have the dealer look at it.
  3. Sep 16, 2009 at 3:45 PM
    JKD
    JKD Well-Known Member
    Could be one of the traction/brake systems doing something for you. Maybe you are breaking a tire free and the TRAC system is activating (reducing engine power and applying the brake to the spinning tire). Maybe your truck has hill start assist (or is that only in manual trans. trucks?).
