Transmission sounds like bucket of bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheTaco09, Jun 27, 2023.
  1. Jun 27, 2023 at 10:52 AM
    TheTaco09
    TheTaco09 [OP] Well-Known Member
    2009 toyota tacoma i4 5spdm
    Urd short shifter Tss wheels
    So I had my clutched replaced at 130k miles, and after I had it replaced I found several bell housing bolts loose and took it back to the shop to have it fixed, however I am now worried that I have other things wrong with my truck. After getting my truck back I started driving it and noticed that when shifting in to 2nd gear going 10 miles an hour up to my shifting point of like 22 ish miles an hour the truck shakes and sounds like a bucket of bolts are just loose in the transmission. this is the case in 3rd and 4th too, but as soon as I shift into 5th and get above 45mph it stops and sounds normal. This noise never occured before getting my clutch replaced, and when I took it to the shop to ask them about the noise they said that I had to drive it harder so it didnt make the noise. But it sounds like its falling apart and I dont trust it.
    I would also like to note, the vibration isn't major, it feels more like if you were driving over very light rumble strips, or if there was a very small shake in the steering wheel. So not major, but still noticable.
    and finally, one more thing, the truck has been driving perfectly other than the noise and slight vibration and it has been like 4 months since the clutch job, and nearly 15k miles.
  2. Jun 27, 2023 at 11:14 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    What kind of clutch did you have installed?
  3. Jun 27, 2023 at 11:30 AM
    TheTaco09
    It was a normal clutch wasnt special, it was like the suggested one, I dont know if it was OEM or anything
  4. Jun 27, 2023 at 11:55 AM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    " drive it harder ", I call BS...
  5. Jun 27, 2023 at 11:55 AM
    TheTaco09
    My thoughts exactly
  6. Jun 27, 2023 at 1:09 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If they left bell housing bolts loose who the hell knows what else they could have messed up. Did they forget to fill it with gear oil? Is the clutch cover coming loose? Probably have to pull the trans again and look
  7. Jun 27, 2023 at 1:10 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    something could be damaged internally if it was driven with loose bell housing
    HondaGM likes this.
  8. Jun 27, 2023 at 1:30 PM
    TheTaco09
    that is worrying, I will take it to a transmission shop this weekend to see what they say as I dont have the ability to pull the trans myself sadly
    HondaGM likes this.
  9. Jun 27, 2023 at 1:32 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What did this clutch job cost out of curiosity?
  10. Jun 27, 2023 at 1:47 PM
    TheTaco09
    it was around 800 roughly? but I have been going there for years, along with all of my other friends and we have never had an issue like this.
  11. Jun 27, 2023 at 3:10 PM
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
    They probably let the 'new guy' work on it
  12. Jun 27, 2023 at 4:13 PM
    lbregman
    lbregman Well-Known Member
    Northern California
    2013 Tacoma ACORMT
    That should not happen, and do bring it somewhere else. Let a transmission shop guy drive it around. Probably unrelated: but I do think your shift points are a bit low. And you could wind it out a bit more.
  13. Jun 27, 2023 at 4:23 PM
    MR5X5
    MR5X5 Well-Known Member
    4 months and 15k miles since the repair is going to be a problem....
  14. Jun 27, 2023 at 4:29 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    exactly. Have someone follow you to a safe place and beat the crap out of it, make it handgrenade. Call those idiots and tell them to send a wrecker. demand a new one
  15. Jun 28, 2023 at 5:49 AM
    TheTaco09
    Typically at what shifting points should it be driven too?
  16. Jun 28, 2023 at 5:49 AM
    TheTaco09
    If it wasnt several months ago, or nearly 15k miles since the replacement I would, but I doubt now they would do anything.
  17. Jun 28, 2023 at 6:40 AM
    lbregman
    Northern California
    2013 Tacoma ACORMT
    Ya know, on second thought this seems like a can of worms and a topic for another thread lol. I think I made that comment as too much of a “statement”. At the end of the day I think going by feeling is best.
    But yeah, I’ve been accused of lugging my engine so I’ve upped it a bit. Your clutch lasted 130 so you’re doing a lot right lol. All I can say is it feels much smoother to me to shift closer to 3000 rpm than 2000, and 3500 if I need to accelerate with most traffic.
  18. Jun 28, 2023 at 6:43 AM
    TheTaco09
    typically I shift at 2750-3300 for accelerating through traffic, and when I am just leisurely driving around I shift at 2k or slightly above, in my truck this typically equates to a shift every 10mph
    lbregman likes this.
  19. Jun 28, 2023 at 7:44 AM
    lbregman
    Northern California
    2013 Tacoma ACORMT
    Cool! I’m just realizing what transmission and engine you have..apologies. But it’s fun to talk about, regardless. Yeah I think in my 6 speed I’m usually shifting into 5th at 50.
    TheTaco09[QUOTED][OP] likes this.
  20. Jun 28, 2023 at 9:13 AM
    TheTaco09
    all good, I wish I had a 6 speed, the 5 is very weird on interstates, I hate driving at 75mph sitting at like 3k rpms constantly, not fun
