Transmission Stuck in gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by amesbury taco, Apr 29, 2024.
  1. Apr 29, 2024 at 6:10 AM
    amesbury taco
    amesbury taco [OP] Member
    2009 Tacoma TRD
    2009 Tacoma TRD, Stuck in Gear and will not start. ( I think reverse ) I was using it to push my docks in. Did the overide and it worked for a bit. This was during COVID. Bought a new Tacoma and this one has sat for 2+ years. New battery, new gas, lights all come on. It's up on a Quickjack in my driveway now. Disconnected shifter cable and lever will not move. used Blaster, Wd 40 etc. Locked solid. Checking fuses today, Would the park/neutral switch lock it ? Lots of rust. sprayed it also. Dash lights indicate it's in 4W low but the switch is set on 2W high. Throwing a code P0705. I am not sure if that is a symptom or cause.
  2. Apr 29, 2024 at 7:13 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Your talking about the lever at the transmission correct?
  3. Apr 29, 2024 at 7:20 AM
    amesbury taco
    2009 Tacoma TRD
  4. Apr 29, 2024 at 7:55 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd suspect the range sensor is the culprit, it's on the shaft on the passenger side of the transmission. It's aluminum and the shaft is steel so it tends to get very corroded.
  5. Apr 29, 2024 at 10:09 AM
    amesbury taco
    2009 Tacoma TRD
    I think that might be right. I thought if I tapped the shifter lever with a hammer it would break lose. Is it on the same rod as the shifter lever on the other side ? How easy is it to replace ? I hear it can be rough and it could break. Also damaging a seal can be a big problem.
  6. Apr 29, 2024 at 10:17 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes it's on the same rod, I wouldn't get too crazy with it.
    They typically have to be cut off while taking care to not damage the shaft or seal.
  7. Apr 29, 2024 at 10:57 AM
    amesbury taco
    2009 Tacoma TRD
    Maybe heat it with map gas or would that melt a seal ?
  8. Apr 29, 2024 at 11:48 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I wouldn't want to heat it too much.
