Transmission Stuck in gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by amesbury taco, Jun 2, 2024.
  1. Jun 2, 2024 at 12:23 PM
    amesbury taco
    amesbury taco [OP] Member
    2009 Tacoma TRD
    Thanks for all the advice. It worked perfect! The new Neutral sensor switch is on, the truck runs, the wheels turned forward and reverse on the lift. dropped to the floor, put it in gear and the gas pedal will not accelerate the motor. It stays in idle.....What now ??
    TnShooter likes this.
  2. Jun 10, 2024 at 3:27 PM
    IA DIY
    IA DIY Well-Known Member
    Iowa
    2008 DCLB 4x4
    Transmissions are the most complex part of the vehicle. A good transmission specialist can diagnose and sometimes offer a fix for $, whereas stealership will usually quote you an entire new unit.
  3. Jun 11, 2024 at 10:55 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the brake pedal switch. There was a safety recall that included a flash to the ECU so that if the brake is depressed and the accelerator depressed at the same time it does what yours is doing remains in Idle.
    Check to see if the brake lights are on or off when you try to accelerate.
