Transmission swap options?
Discussion in '1st Gen. Tacomas (1995-2004)' started by toypower, Dec 28, 2014.
  1. Dec 28, 2014 at 8:42 AM
    toypower
    toypower [OP] Well-Known Member
    corey
    Niceville FL
    98 Reg Cab Tacoma
    Sas swap, dana 44 high pinion front, Corporate 14 bolt locked, disc brake conversion. 8 inch superlift springs on 39.5 iroks, 5:38 front and rear. Hydraulic assist, 3 inch body lift, Yukon axles front/rear, bilstein shocks, CAI, rock ripper header.
    My W-59 finally gave out. Good luck finding any W-59s where I'm located I've been looking since 2013. I was just wondering if anyone had any information on any other transmissions that I could use with my W-59 bell housing. My truck is a 1998 2.7. Saw a few pics online of a 1999 v6 transmission and it looks the same. The v6 trannies seem to be pretty common around here. I just wanted some info before I pulled the trigger
  2. Dec 28, 2014 at 9:53 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    it is my understanding the trannys are fairly standard and swappable but you need to make sure its from a truck with the same wheel sizes or just swap out the speedo gears so it reads the correct mph.
    this is what I have come to understand just from reading posts about people needing trannys so I cant say this is to be taken as fact
