Transmission Swap!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomaguy0111, Jul 9, 2013.
  1. Jul 9, 2013 at 12:23 PM
    Tacomaguy0111
    Tacomaguy0111 [OP] Member
    Calabogie.ON
    07 Tacoma 4x4
    6" lift, flow master exhaust, K&N intake, Throttle body upgrade, Centerforce Clutch, 35" tires
    Hey Everyone,
    I plan to swap the transmission in my truck soon. Just wondering how long it will take to swap? Should I change any bearings/other things while I have it out?
    Thanks,
  2. Jul 9, 2013 at 12:26 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    You could probably drop it out, put it back in 12 hours (shooting high) Depending if it's a 4x4 (assuming it's on your 07)
  3. Jul 9, 2013 at 12:26 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    What are you swaping it with? Curious.
  4. Jul 9, 2013 at 12:52 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    X2 on around 12hours. Some of the mounting bolts are a bitch to get in and torque. Make sure you have a good variety if tools. Swapping is pretty straight forward if you have the fsm. I wouldn't change any bearings or crack it open unless you know exactly what your doing. What's wrong with it?
  5. Jul 9, 2013 at 12:59 PM
    Tacomaguy0111
    Calabogie.ON
    07 Tacoma 4x4
    IM swaping it with another(same) tranny. My reverse Snycro gear is messed. ( slips out of reverse and hard to get into reverse) and will sometime grind while changing gears. Also I need a new release bearing-throwout bearing, its squeaking like crazy. I didn't realize it would take that long. going to be $$$$
