Transmission swap.
Discussion in 'General Automotive' started by BurritoClimber, Dec 23, 2020.
  1. Dec 23, 2020 at 12:04 AM
    BurritoClimber
    BurritoClimber [OP] Well-Known Member
    2007 Tacoma 2.7L
    It is just a general automotive question. If you swap the engine, do you need to swap the transmission as well? I know its best to swap when you take the engine out. Also if you have had an engine swap, or have a vehicle with an engine swap, could you swap the transmission for the vehicle, or would you need to get a transmission specifically for the engine?
  2. Dec 23, 2020 at 12:13 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    No you don’t have to swap the transmission.
    If your transmission is fine, I’d keep it.
    Sometimes depending on the model changes you may have to swap connections, etc.
    That’s work I would rather not do if I don’t have too?
    Sometimes you can swap transmissions.
    I really depends on the vehicle, year, type transmission.
    To keep it “simple”. I wouldn’t swap a different transmission if I didn’t have GOOD reason.
  3. Dec 23, 2020 at 12:19 AM
    BurritoClimber
    2007 Tacoma 2.7L
    Yeah, that makes sense. Thank you!
    TnShooter[QUOTED] likes this.
  4. Dec 23, 2020 at 8:13 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If you are swapping the same engine as stock then you are fine with the current transmission
    TnShooter and Tacospike like this.
