Transmission Swap
Discussion in '1st Gen. Builds (1995-2004)' started by Elijahsleeper, Jan 18, 2023.
  1. Jan 18, 2023 at 6:02 PM
    Elijahsleeper
    Elijahsleeper [OP] Member
    2003 Toyota Tacoma
    URD Short throw shifter, Vortex cold air intake, upgraded performance headers, LED ditch lights with wire harness, upgraded headlight bulbs, aftermarket stereo system, billet aluminum shift nob, Rugged floor mats, plastic bed liner, ceramic clutch, oversized injectors with ECU tune... Lots more to come.
    I have a 2003 Manual Toyota Tacoma (SR5 2.4L extra-cab). I intend to make this a sleeper.
    I want to upgrade my transmission to have taller gears without extreme hassle.
    I want to do this because I have been making minor modifications to it for performance but now the next step is to install a LCE engineering turbo kit that will be running ~15PSI boost. With this upgrade I want to upgrade my wheels to 235/55R-17 99V HITRAC to keep handling/acceleration.
    The combination will put a lot of extra stress on the transmission and the current transmission is a bit slow since I already run through the gears quickly, thus spending a lot of unwanted time shifting. Does anyone know of a good manual transmission swap from a performance vehicle?
  2. Jan 18, 2023 at 6:03 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
  3. Jan 18, 2023 at 6:09 PM
    Clearwater Bill
    Billy
    Largo Florida
    A 5 lug sleeper based on a 2.4.
    Interesting.
    And before we get to the transmission, how is the engine prepped to handle 15# of boost?
  4. Jan 18, 2023 at 6:18 PM
    Elijahsleeper
    2003 Toyota Tacoma
    The engine has been well maintained. The block is strong enough as is (stock) since it is an alloy. I had the valve cover gasket replaced. I also had oversized injectors put in. The fuel pump is fine as is. The intake was changed to a vortex cold air intake so it can breath easy. To make sure their wasn't too much back pressure I upgraded to performance headers. I also have it tuned for this so far.
    When I do the turbo kit I will put in forged pistons and new crank rods to make that rock solid. Obviously a new tune with all these upgrades is necessary for secondary balance. Primary balance in the 2.4L is amazing.
    I just don't want to do all this work if I don't have a plan for my transmission. I have seen guys on the internet do the high boost kit and blow the transmission. I have also seen guys drag race with an LS swap and blow the transmission. Additionally, with this transmission their is rev hang so I wouldn't be able to keep up with a sports car if even if I upgrade all these other parts and can push 250 WHP.
