Transmission swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ajglenn90, Jun 25, 2023.
  1. Jun 25, 2023 at 8:28 PM
    Ajglenn90
    Ajglenn90 [OP] Member
    Amber
    So throwing out the t100 and want to go different way with it so here is my question can you take a manual transmission from a Tacoma and put it in to a automatic 4runner thank you for your help really appreciate it
    Both are 3.4 engines and 4×4
  2. Jun 25, 2023 at 8:53 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    @Kwikvette
    @eon_blue
    @Taco critter
    I know there are some good auto to manual swap threads out there for 1st gens. Probably never been done with a 4runner trans, but figured you guys might know.
    Taco critter likes this.
  3. Jun 25, 2023 at 9:00 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    4Runner?
    Auto to auto I say yes, but auto to manual...I can't confirm bell housing, etc.
    Are they both 4x4?
  4. Jun 25, 2023 at 11:27 PM
    Ajglenn90
    Amber
    Yes they are both 4×4
  5. Jun 26, 2023 at 6:09 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The end Goal you want a 5 speed 3rd generation 4Runner??
    Any manual to automatic transmission swap has the same issues.
    Here again use the transfer case attached to manual transmission .
    The interesting issue to get the 4Runner ADD system to work.
    installing the Clutch pedal bracket and hydraulics .
    The different drive shaft lengths.
    OP if you have emission inspections without the changing of the wiring the MIL will be on. Here in Pa that causes a failure to pass the test.
    Now the wiring problem you can swap the engine harness and ECM from the Tacoma to the 4Runner .
    Then repin the 4th ECM plug to match the 4Runner harness .
    You could repin the ECM in the 4Runner to work.
    Even having done a few of these swaps Things always slip my mind. Each swap is always going to be some what different.
    Not something I would attempt with out some skilled help without the complete donor vehicle sitting within a few steps.
    The grunt work is pretty basic .
  6. Jun 28, 2023 at 4:26 PM
    Bivouac
    Any updates or decisions ??
    Maybe Help in your regional forum.
  7. Jun 28, 2023 at 9:05 PM
    BlondeBTCH
    BlondeBTCH Member
    Would a R-155 transmission work. There’s a R-155 for the 4x2 for sale. The R155F is for 4x4’s. We understand that the output is different for the 4x4’s. The R155 is on FB Market Place with 36k miles. It’s in central Texas.
