Transmission temp gauge on 1st gen Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Coho1249, Jun 30, 2019.
  1. Jun 30, 2019 at 3:48 PM
    Coho1249
    Coho1249 [OP] New Member
    Are there any write ups on installing a transmission temp gauge in a 98 Tacoma someone can lead me to? I believe I have the OBI 1 not sure though. I’m hauling an in bed pop up camper that weighs 1300lbs loaded and I don’t want to over heat tranny when in mountains. I do have a trans cooler installed.
  2. Jun 30, 2019 at 4:24 PM
    Good deal
    Good deal Well-Known Member
    Texas
    If I'm not mistaken automatic transmissions have a line that connect to the bottom of the radiator thus cooling the automatic transmission. I know this because when I installed the radiator on my manual transmission I kept that bottom port capped.
  3. Jun 30, 2019 at 6:17 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I've read a lot of people using Scan Gauge (about $140 on Amazon), but I do not have one. Also, several have said the Ultra Gauge ($much less) can be programmed to read trans temp.
  4. Jun 30, 2019 at 6:22 PM
    Clearwater Bill
    Billy
    Largo Florida
    OBDII was required from '96 up if memory serves.
    Real time tools can only read what the ECU outputs. If the vehicle didn't out put trans temp, one of those tools won't get it done. You probably determine that by going to a site like ScanGauge and looking for what they call X codes for your year, brand, model. No code? No output to be read.
    Your second choice is to install a traditional sensor in the trans cooler circuit and montior with an auxillary gauge in the cab. A lot more work, some risk of leaking if not done right or damaged in the future, and a one horse show. But effective.
