Transmission Temp Sensor & Gauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blazze2005, Mar 22, 2010.
  1. Mar 22, 2010 at 5:17 AM
    blazze2005
    blazze2005 [OP] Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Would it be possible to run a Transmission temp gauge by tapping into the wires on the factory trans temp gauge?
    I noticed there is a trans temp sensor located on the top side of the transmission on my 05 tacoma pre-runner
    Would like to hook up a digital gauge
    Thanks for any info on doing this...
  2. Mar 22, 2010 at 5:20 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  3. Jan 29, 2013 at 11:58 PM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
  4. Jan 30, 2013 at 12:33 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Is there an updated ultrguage?
    I have coolant temp, but not trans temp....that would be awesome!
  5. Jan 30, 2013 at 3:34 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    The newer Scangage can display both trans pan fluid temp and Converter fluid temp. Mine is setup to show both simultaneously.
    I don't know if Ultragage will or not.
    Rather than a work the oem wiring if you do not go Scangage, add a remote trans filter and install a temp probe in the fluid return line from the cooler. Or better yet, add an aftermarket cooler with the fittings already in place for the temp probe. Then run whatever gage setup you prefer.
    PK
  6. Jan 30, 2013 at 6:28 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Which trans temps the SG gives depends on the year of the truck, for 10+ you can get the pan and converter temps via an Xguage setting, 05-09 only gets the pan temp.
    UG cannot do trans temps at all.
  7. Feb 22, 2013 at 10:50 AM
    jjhitchen
    jjhitchen Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
  8. Feb 22, 2013 at 10:56 AM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    Can also read it using the Torque app ($4.99) on my Droid that talks to my $15.00 OBD-II bluetooth sensor. I have about $20.00 invested in a very powerful and useful tool.
  9. May 4, 2013 at 5:02 PM
    gjtacoma
    gjtacoma Active Member
    San Diego County
    4x4
    Which bluetooth sensor did you go with, from where?
  10. Jul 30, 2013 at 11:51 AM
    dbbyleo
    dbbyleo Active Member
    In terms of where to mount the temp sensor, have you guys read or heard of doing this: I'm thinking about doing this same setup, but wanted to see if anyone else have done it and how it's worked out in the long term?
