Transmission temperature for checking fluid level?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DarkSky, Nov 29, 2016.
  1. Dec 1, 2016 at 3:47 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Yes; shift through the gears to cycle.
    By three times, I mean repeat the whole procedure three times. My point being is it will require at least 9.9 quarts, plus whatever it takes to achieve overflow; it's not just replacing 3.3 quarts like the chart would lead one to believe.
    ...and fnish with temp check procedure and reset thermal degradation value.
    SOSHeloPilot[QUOTED] likes this.
  2. Jul 29, 2018 at 12:12 PM
    PreRunnerAlabama
    PreRunnerAlabama Well-Known Member
    2015 Black Toyota Tacoma PreRunner I4
    TRD Sport 17" rims Fog Lights OEM Curt Receiver and Hitch
    Thank god I have the 2.7 L. This is ridiculous, the user doesn’t even have the ability to check their on transmission fluid level. Cannot stand these modern transmissions by Toyota. Put a freaking dip stick in the damn thing. Ridiculous.
    Mech_Eng likes this.
  3. Jul 26, 2023 at 11:20 AM
    RyanV1
    RyanV1 Active Member
    Austin
    93 4x4 Ext Cab Pickup 2RZFE
    This is an old thread, and it has misleading info in it. The sealed 750 series transmission fluid level check range is 115-130deg F per the Factory Manuals. The trans will drop a little over 2.5qts with each drain. Techstream displays both transmission temp sensors. Wait until both sensors read at least 115 deg before popping the overflow plug
    The trans fluid takes a long time to reach 115 and will stay in range for quite some time. Be very careful not to burn yourself on the exhaust.
  4. Jul 27, 2023 at 5:32 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
