Transmission Temperature??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacosForever, Apr 25, 2016.
  1. Apr 25, 2016 at 7:23 AM
    TacosForever
    TacosForever [OP] Active Member
    2016 Quicksand Tacoma TRD 4 Door Long Bed
    Tinted Windows Bed Mat
    Can i just beam the pan or one of the transmission lines to the
    cooler with my temperature gun for that 113 degree temp that i need
    to check my fluid or does it HAVE to be in that stupid temperature check mode?
    Thanks John
  2. Apr 25, 2016 at 8:44 AM
    TacosForever
    Whats the proper way to get it into temperature check mode? Jump OBD port 4 and 13 and then what? Or is that wrong already?
  3. Apr 25, 2016 at 9:13 AM
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    Just to clarify - the 60F is 4WD and the 60E is 2WD. However, they are basically the same transmission with either a transfer case or a tail shaft bolted on the end.
    Vbpiper likes this.
