Transmission thump going to Drive
Discussion in '1st Gen. Tacomas (1995-2004)' started by DNG, Oct 20, 2011.
  1. Oct 20, 2011 at 1:25 PM
    DNG
    DNG [OP] Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    I'm getting a noticeable thump when shifting to drive, mostly from reverse but sometimes even from park. It seems like the gears aren't engaging smoothly. It's definitely coming from the tranny and it's not axle wrap. Is this something I should be worried about?
  2. Oct 20, 2011 at 2:13 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner
    sounds like a bad trans or motor mount crawl under there with a pry bar
  3. Oct 20, 2011 at 2:13 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    check the motors and trans mounts
  4. Oct 20, 2011 at 4:39 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    How does it upshift ?? smooth & predictable ? or erratic & hard ?
    why so sure its not axle wrap?, that shit works in strange ways ....;)
  5. Oct 20, 2011 at 4:41 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Universal joints??
  6. Oct 20, 2011 at 4:42 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You dont want to find this in your pan....
  7. Oct 20, 2011 at 4:44 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    :rofl:
  8. Oct 20, 2011 at 5:21 PM
    DNG
    Orange County, CA
    I'll check the mounts. Sounds like that could be it.
  9. Oct 20, 2011 at 5:25 PM
    DNG
    Orange County, CA
    The only "problem" I have is with 1st gear. Seems like with a slow take-off, first gear almost feels like I'm revving in neutral until it shifts to 2nd. Other than that, the rest of the gears are smooth.
    I'm not 100% it's not axle wrap. I've felt some axle wrap (the feeling of being rear ended), and this is definitely a different feeling. Only happens when I'm shifting from P to D or from R to D.
  10. Oct 20, 2011 at 6:16 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    have you checked transmission oil make sure it still red and not a burning smell? When was the last time the tranny filter was changed?
  11. Oct 20, 2011 at 9:01 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I'd laugh with ya too if it wasn't 2K & up to fix it.....:(
  12. Oct 25, 2011 at 12:25 PM
    tacoman78
    tacoman78 Well-Known Member
    Bakersfield, CA
    02 Limited Dbl Cab Prerunner
    Deck Mod
    From what your typing it sounds like the transmission could be slipping.
    Follow these steps:
    1. Crawl under and look at your mounts. If they are bad replace them. If they're good proceed to step 2.
    2. Check your transmission dipstick (make sure the engine is running). Make sure you have enough fluid in the transmission. Check if the fluid is still red and doesn't smell burnt. If everything checks out there Proceed to step 3.
    3. Pull the plug on your tranny pan, drain the oil of out if and then pull the pan. See if you have any metal in the pan, slivers and chunks are bad. This is were your going to find if you need to take your truck to a professional. Be prepared to hand over about 1.5 ounces of gold as well.
    If your pan is empty of any metal...then you have a serious problem somewhere else that is undiagnosable in an online forum setting and you should probably go to reputable repair facility and pay them to diagnose your problems. Be prepared to pay about $100-$150 for a complete diagnosis. Best of luck.
