Transmission Thumps from (P) to (R) to (D)
Discussion in '1st Gen. Tacomas (1995-2004)' started by yoTaco98, Jul 11, 2011.
  1. Jul 11, 2011 at 8:48 PM
    yoTaco98
    yoTaco98 [OP] Well-Known Member
    Yo
    VA
    1998 V6 Xtra-Cab Tacoma 4x4 SR5
    5100's Front and Rears, Toytec Eibach Coils, All Pro 3" Standard Leafs, BAMF BPV Bracket, ARMA Sprayed Bedliner, TGD Hunter Bull Bar, Blacked-out Headlights and Corners, Revtek 1" Diff Drop, Start Command Remote Start and Keyless Entry, Pioneer DEH-11E HU...
    Guys,
    I bought the truck used and it was very well maintained. Fresh oil, transmission fluid clean, interior clean, engine runs smooth...
    The transmission is very smooth when I'm driving. The changes from 1st to 4th gear are smooth, and I have no complaints.
    But as the title states, when I'm changing the shifter from Drive to Reverse, or Park to Drive, or Park to Reverse, I feel a massive thump when it engages.
    Could it be that my transmission mount is shot after 13 years, 174k miles?
    Had anyone else had this issue? Did replacing the transmission mount correct it?
    This guys advertises that this heavy duty mount will correct this problem. (4xInnovations)
    http://4xinnovations.com/p-TCC1326.html
    Anyone try this mount?
    Like I said, the shifts while driving very smooth. The transmission fluid, pinkish/clear in color, and I have an appointment on Friday for a possible flush.
    Thanks in advance guys!
  2. Jul 11, 2011 at 9:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Are the rear leaf springs the originals. Sounds a lot like simple axle wrap.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/106081-drivetrain-thud.html
  3. Jul 11, 2011 at 10:36 PM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    As said above. And since Tacomas are rubber mounted trannys to the shifter, it tends to vibrate. Mine does this too i just got used to it. This is a common problem.
  4. Jul 12, 2011 at 3:45 AM
    yoTaco98
    Yo
    VA
    They are the orignal leaf, and they are extremely worn, basically completely flat, almost inverted.
    I knew I had axle wrap since I get a massive clunk when I let off the brakes at a stop light. I just didn't know that it would cause the shifting to clunk as well.
    Guess it's time to replace the leafs.
    Whose replacement leafs eliminate axle wrap the best?
  5. Jul 12, 2011 at 2:52 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Well, most leaf packs you'll find will lift it some. So you might as well lift the front some with eibach coils and 5100s. Then you'll need some new tires to fill out the wheel wells and probably new wheels with less backspacing to keep those new meats from rubbing. Then you'll probably want some armor to keep from damaging your baby when you're wheeling and using all your new found offroad ability. Then you'll want a winch and lockers to go even farther with your new truck...
    Welcome to the black hole that is modding your truck. "If you give a mouse a cookie..."
  6. Jul 12, 2011 at 4:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I really like my alcans. These will give about 2" of lift.
    http://www.wheelersoffroad.com/9504tacomaacleafsprings.htm
  7. Jul 12, 2011 at 5:01 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds almost like classic axle wrap to me... Long, flimsy rear leafs = axle wrap, just about any additional stiffening of leaf pack will eliminate it.
    Edit: An AAL might not completely eliminate it, but the addition of 2 leafs per side will, I guarantee it ....;)
  8. Jul 12, 2011 at 6:52 PM
    Nolawall
    Nolawall "And there I was just minding my own business"
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    6" Fabtech Suspension Lift. K&N Air Filter Cobra 18 CB with 2 3' firestik II antennas
    OK well I am completely new to Tacomas, I just bought a 2002 with a 6'' fabtech suspension lift and 305/17 R16's Mickey thompson Baja ATZ's. This stuff is all new just put one. Well there is 2 things that I am noticing that the guy I bought it from didnt tell me and I didnt know better to catch this.(1) When I am at a light I feel the clunk when I let off the brake. so now reading forum this i know this is axel wrap. (2)I have and automatic tranny when I am sitting at a light I give it gas I can feel the shifter move. which makes me think that the transmission is shifting and i need to get a better transmission braket is this correct. So what is the best way to fix these issues. Is this normal when someone put this fabtech lift on this truck I hope i didnt buy into something that I will be totaly screwed
  9. Jul 12, 2011 at 7:04 PM
    yoTaco98
    Yo
    VA
    I'm just surprised that axle wrap could be the cause of the shifter thumps.
    Has anybody tried these Fat Bob's 2.5" leafs?
  10. Jul 12, 2011 at 7:33 PM
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    Should i just get track bars for the rear i dont even know if that lift came with track bars.
  11. Jul 12, 2011 at 8:05 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Oh yeah... That axle wrap rears its ugly head at the damnedest times, consider that weak/soft springs are going to allow your axle to rotate forwards & backwards while slowing or when gas is applied too...
  12. Jul 12, 2011 at 8:16 PM
    yoTaco98
    Yo
    VA
    I definitely know that the axle wrap exists when I take off and stop,,,especially stop.
    My big concern and reason for the thread was the shifter thump, when I am not driving.
    (i.e.) When I turn the truck on in the morning, and shift into DRIVE for the very first time, it thumps into DRIVE. If I'm backing out of a parking spot, and I shift from PARK to REVERSE, it thumps.
    I don't think this could be axle wrap, but a bad transmission mount instead.
    I'm going to check out the local salvage yard this weekend for a leaf, and hopefully a temporary fix for the axle wrap.
    But this shifter thump has to be the transmission mount, don't you all think? Is there a way to check if my transmission mount is bad, kinda like power braking to test a motor mount?
  13. Jul 12, 2011 at 8:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have a little trouble believing its a broken or even a bad trans mount. There too many other more likely suspects. Is your slip joint dry? How about the u-joints? What is the condition of your carrier bearing. All of these items are more likely.
    Maybe one option you have before you start throwing cash at this thump, is to crawl under there and observe while a buddy does the things that cause the thump. See if you see some movement where there shouldn't be any. Maybe hear the noise better.
  14. Jul 13, 2011 at 4:20 AM
    yoTaco98
    Yo
    VA
    Ok..Dumb question time.
    I was plannng on geasing all the zerks this weekend. Would that target the U joint and slip joint?
    And where exact is the carrier bearing?
    Good idea...I'll lay under there this weekend after I grease the fittings and have someone shift from P to D To R and see what moves
  15. Jul 13, 2011 at 5:21 AM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2017 TRD OR DCSB BBP
    Grease won't fix a bad u-joint. While under the truck, grab the drive shaft and try to turn it back and forth and look for movement at the u-joints.
    The slip joint is lubed with a zerk and is back in front of the rear diff. It may take a few pumps to get it lubed if it is real low.
    The carrier bearing is in the middle of the drive shaft. It is the round metal with rubber inside bearing holding the drive shaft. Grab the drive shaft near the carrier bearing and push up and down to check movement.
  16. Jul 13, 2011 at 6:48 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Check the u joints and the motor mounts.
  17. Jul 13, 2011 at 7:04 AM
    yoTaco98
    Yo
    VA
    Thanks for this information.
    I'm changing all the front/rear, and tansfer fluid this weekend to Mobil 1, and lubing all the zerks.
    While I'm down thee I'll check all U, Slip, and Bearing.
    I just read in the Haynes manual that you cna also just your transmission mount by placing a crowbar or some thing similar between the two plates and pushing up and down to see if there play in the rubber mounts between them. So I'll check this too and the engine mounts.
    As for the grease, there a particular brand that's better than another. I bought Red n Tacky #2. Is there something better?
  18. Jul 13, 2011 at 7:50 PM
    tacoma04
    Bruce
    Northern Louisiana
    Red n Tacky is good. You will find a number of folks on here that use it with good results.
  19. Jul 13, 2011 at 7:56 PM
    yoTaco98
    Yo
    VA
    Checked the U joints, there wasn't any play in them.
    I pushed up on the carrier bearing and it had about a 1/2" of upward play, maybe 3/4“ if I pushed really hard. Is that bad?
    I'll lube the slip joint this weekend with the Red n Tacky.
  20. Jul 13, 2011 at 7:58 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    when you are shifting from R to D or what ever you are doing... what are your rpms? when you get in the truck are you waiting for the rpms to go down bfore you shift into R? i have just about 5,000 miles on my truck, and when im in a hurry...(start and go) it sounds like the same thing. but it only does it when im start and go.
