Transmission/Transfer case clunking normal?
Discussion in 'Technical Chat' started by Cygan, Aug 24, 2009.
  1. Aug 24, 2009 at 1:06 PM
    Cygan
    Cygan [OP] Active Member
    Hello all. I just picked up a 2.7 4x4 Access cab. The thing has 700 miles on the clock. Ever since about 300 miles I noticed this clunk. When lurching forward, or reverse for that matter, then engaging the clutch there is a metal to metal clunk. I also hear it when in 4th or 5th doing about 50-60, letting off the gas and then getting back on it tho its not as pronounced. The sound seems to come either from the transfer case or the transmission.
    I went to the dealership this morning to have it checked out. The mechanic told me that it was normal for this truck. Can anyone out there confirm that this is in-fact "normal" for this truck?
  2. Aug 25, 2009 at 8:55 AM
    Cygan
    Anyone? All I need is a yes or no. Please help
  3. Aug 25, 2009 at 9:32 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
  4. Aug 25, 2009 at 10:02 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you in 4WD when this is occuring?
  5. Aug 25, 2009 at 10:23 AM
    Cygan
    It happens in 4WD as well as 2WD
  6. Aug 25, 2009 at 10:35 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    Manual transmission 4x4s I have had in the past did that upon sudden pressing of the gas (when coasting) or sudden deceleration of gas (when under throttle). Usually some slack somewhere in the drivetrain could be the transfer case chain, ring and pinion, or somewhere else. I wouldn't worry about it. Its usually more noticeable in manual gearboxes since they is no slippage when the clutch is engaged. Most often just normal mechanical noises.
    Good luck. Hope this helps.
    EDIT: You probably noticed it after 700 miles when you started to get more comfortable with the truck. Thats when I usually notice noises.
  7. Aug 25, 2009 at 12:28 PM
    Cygan
    It definitely puts me somewhat at ease. I've had a jeep guy tell me that his Jeep does the same thing. But I also had a guy who has a 88 toyota 4x4 with over 300k miles tell me that his tin can does not clunk. I'm not sure what to believe here.
    I actually noticed the clunk at around 260 miles which is about 100 miles after I picked her up. At 700 miles its annoying the shit out of me :(
    Lord Humongous likes this.
  8. Aug 25, 2009 at 12:32 PM
    rutherk1
    09 Silver TRD 4door
    His 88 didn't do that because the transfer-case was all gears. Yours and mine have a huge chain in it. There is some slack so it wont snap. Im willing to bet, that is what you are feeling. Its just exaggerated because you have a manual transmission.
  9. Aug 25, 2009 at 12:46 PM
    TacoOwner?
    TacoOwner? Well-Known Member
    Joshua
    Camas/Spokane, WA
    '10 4x4 Double Cab 6M
    Anti-thief tailgate, anytime rear-view camera, anytime locker mod
    Great info. +1
  10. Aug 26, 2009 at 7:06 PM
    Cygan
    Thanks for the replies, especially rutherk1. I do feel a little better. I'm not as worried but still annoyed :)
