TRANSMISSION . Transmission coolers for all Toyotas ... Write up with many pictures
Discussion in 'Technical Chat' started by gearcruncher, Dec 30, 2017.
  1. Aug 21, 2024 at 12:13 PM
    #361
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Some of the bypass style coolers just use smaller internal passages in the larger portion of the cooler. So that when cold and thick it flows easier thru the upper portion of the cooler since passages are larger. As the fluid thins as it heats up it can then flow more thru the lower sections. So its never a 100% bypass.
    Other use and actual bimetal thermostat plate/tab that block the flow until it reaches a certain temp.
    I wanted more control over the cooling from the add on cooler so am using an actual oil thermostat that only opens when temp reached 180F.
    So until it reaches 180F its just using the original factory ATF cooler. With this setup I have never seem temps higher that 175F and lows around 140F during the winter.
    I have the 750F trans in my 2015
    Kane50 and CygnusX191 like this.
  2. Aug 21, 2024 at 12:30 PM
    #362
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have one of those units I am installing.
    CygnusX191 likes this.
  3. Aug 21, 2024 at 2:25 PM
    #363
    babylon5
    David
    Even these real oil thermostats are not 100% bypass. When closed they still allow 10% flow.
    From product description " At temperatures below 180° F the valve is open with 90% of the oil bypassing the cooler while the remaining 10% of the oil flows through the cooler. This maintains constant system pressure, preventing air pockets and eliminating cold oil shock"
    On a previous vehicle i installed the same cooler I had without a thermostat. After heavy traffic on a 90+F day I got home and checked the fluid temp using the dipstick (remember those :rofl:) and it was barely warm at all. I knew when winter rolled in it would be way to cool so next was the thermostat install.
  4. Aug 21, 2024 at 4:30 PM
    #364
    babylon5
    David
    And IMHO the the concept of the in radiator ATF line as being used to warm up the fluid is incorrect at least in the case of very cold temps where you would think it was designed to do.
    If its very cold (say -4F) and you are moving so there is airflow then the coolant in the rad isn't going to be very warm at all. If the rad has the capacity to cool the engine at 90F then its barely being utilized at very low temps.The engine thermostat will barely have to be open to keep the engine at operating temp.
    So at really cold temps I can see the in rad atf line as being a cooler. And seeing that the in rad line is located on the other side of the radiator than the coolant input line from the engine its even cooler that what being sent to the rad from the engine.
    I like the concept and the idea of having the ATF thermostat located in the transmission itself as long as the actual ATF cooler that is used has sufficient capacity to indeed keep it cool.
    If i was to redesign the system I now have I would eliminate the radiator cooling line and run the fluid thru a true thermostat and then a decent cooler. This should serve to bring up the ATF to a proper temp quickly and keep it at a very tight temperature range.
  5. Aug 24, 2024 at 8:22 PM
    #365
    afcope
    afcope Member
    @babylon5 that's the path I am going to take. I like how cool the 4590 keeps my transmission even when it's 115F, uphill, in a headwind...I just need a bypass for when it's cool. Thanks!
  6. Aug 24, 2024 at 9:10 PM
    #366
    Tacogent
    Tacogent Well-Known Member
    Nonw Stock
    Hmmm.... If I didn't have at T-Stat, I'd probably do the same !!! I know I could reroute the Trans oil lines now, but for ......1) springing for a TC 4590 and a Derale fluid control thermostat, ( $100.00 + and $70.00 respectively), something like those bucks $$$ and 2) all my additional labor, I just might've just done/do it!
    I think your reasoning is sound.
    I can't see any conflicts in your automobile logic ...
    Buuuttt, ...... I'll work with what I have ....
    Look at that face !!!
  7. Aug 25, 2024 at 6:31 AM
    #367
    babylon5
    David
    Now in the 40+ years I have been driving I have never seen it happen but with the atf coil in the radiator there has been the odd mention of the dreaded pink milkshake where the line corrodes and coolant mixes with the ATF. So if you bypass the rad all together you would never have this to worry about. If i ever had to replace the radiator I would just go for one from a manual trans model and skip the in rad atf cooler altogether (running a real atf thermostat and decent cooler alone).
    I-Give-Up and CygnusX191 like this.
  8. Aug 25, 2024 at 10:56 AM
    #368
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    The AT models only started doing this around 2020 or so. You'd be fine with your 2015.
    But also, regarding the dreaded milkshake
    See "Nissan Frontier smod, 2005-2011"
    Talk about bad design
    Speaking of the 19 plus hundras run a line with coolant through the transmission housing to cool the transmission instead of the other way around. I'm surprised there haven't been more problems with this, but I'm guessing that engineering is solid since it's been 5 years since they started doing that and we haven't really seen problems with it.
  9. Aug 31, 2024 at 5:08 PM
    #369
    I-Give-Up
    I-Give-Up Well-Known Member
    West Phoenix, AZ
    2023 Ice Cap Tacoma TRD
    Meso spare fuse holder. Aluminum gas cap holder. Genuine Toyota bed lights. Bed molle racks. Ammo case storage under hood. In-bed spare tire. Automatic underhood lights. Gooey glurp on frame.
    Is that picture at Berlin, NV?
    rcn[QUOTED] and CygnusX191 like this.
  10. Sep 3, 2024 at 4:46 PM
    #370
    rcn
    rcn Well-Known Member
    Robert
    NV
    2014 Taco Reg Cab 2.7, auto, 4x4, 4.88’s
    2.5” 5100's Icon delta UCA, Icon RXT leafs 255/85r16, 4.88’s
    It is! Good eye!
    My wife and I take truck camping all over Nevada when we have the time. Although when we went Berlin-Icthysaur, it was hot, so it was a day trip.
  11. Sep 7, 2024 at 11:05 PM
    #371
    Tacogent
    Nonw Stock
  12. Sep 7, 2024 at 11:24 PM
    #372
    Tacogent
    Nonw Stock
    CygnusX191 and rcn like this.
  13. Sep 8, 2024 at 7:50 AM
    #373
    rcn
    Robert
    NV
    That’s correct! I didn’t know about any of that besides Great Basin and Death Valley being located in some dark sky country.
    Berlin-Icthysaur is very unique. I love central and eastern Nevada. My wife and I will probably return at some point as we didn’t spend enough time there I feel like.
  14. Jul 21, 2025 at 8:28 AM
    #374
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Question about installing a cooler and bypassing (not using) the radiator to cool the atf. Do you loop the line at the radiator back to itself with fluid in it? Or what's the proper way to bypass the radiator cooling? I don't want to end up with a leaking radiator into my atf costing me an atm.
  15. Jul 21, 2025 at 9:30 AM
    #375
    babylon5
    David
    You can just disconnect the lines at the rad. If you are truly not using the rad a teeny bit of ATF that is in the internal cooling coil will leak out and thats it. For cosmetic sake you could thread a plug into the fittings or just fit a rubber cap on metal fittings that remain after you remove the hoses.
    Once you bypass it is is no longer functional. Just an empty tube. Why would you worry about rad fluid leaking into your ATF if its totally out of the loop???
    CygnusX191 and BabyBilly like this.
  16. Jul 21, 2025 at 9:35 AM
    #376
    Y2kbaja
    Sacramento
    Total Chaos
    It's mentioned in this thread and I've seen it at our shop where the coolant portion of the radiator can leak into the atf side of the radiator contaminating the atf resulting in an expensive atm replacement. This is why I want to add the cooler and not use the radiator to cool the atf.
    I'll either loop the atf fittings at the radiator or plug them off. I still want to be able to use it if I'm on the trail and the external atf cooler or lines leak. Seen that too.
  17. Jul 21, 2025 at 9:43 AM
    #377
    babylon5
    David
    You are referring to the dreaded pink milkshake. I have heard mention of that too. Looping them might be the best idea if you plan to use it in emergencies since the cooling hose you use would then be there to help refit it. That is of course unless you carry spare cooling hose with you. Up here where it can get quite cold I still have the rad in the loop since does help to get the atf up to a working temp faster.
    Keep an eye on the atf temp after you do the bypass. Running to cold is also not a good thing for the ATM or the engine either. I aim for a range of 160-180F (max) and have the regular tow package cooler plus a 180 oil thermostat and a secondary 24,000 GVW plate and fin cooler on the other side of the thermostat.
  18. Jul 21, 2025 at 9:57 AM
    #378
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    I'm chuckling a bit at this because I did it on my first car, a 95 civic when I was wee lad. I inadvertently bought a radiator for an auto to replace the leaking one in my manual trans, not realizing that there was a difference and that the auto had the separate cooling section for the trans lines at the bottom. Even though it was dry being a new radiator, I ran some lag bolts into the fittings and soldered them.
    Short story turned long...yeah, just bypass it.
  19. Jul 21, 2025 at 10:01 AM
    #379
    babylon5
    David
    No needs for solder/bolts. Even just squirt some RTV in both fittings and your done. Or just leave it open. Nothing going thru it anyway. And i wouldn't use lag bolts since this is a pipe thread. Just regular pipe thread brass plugs in most american cars. Think its 1/4 npt. As for imports I have never bothered to look
    Some of these rads use plastic tanks now. I would use the least forceful method of blocking off these fittings. These tanks break easily. If never using the ATF cooler look I would stick to just RTV in both fittings
    Barsoom, CygnusX191 and BabyBilly like this.
  20. Jul 21, 2025 at 10:28 AM
    #380
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    oh i know it was totally unnecessary. Coulda just left them wide open or cut off the fittings. i was like 16 and didn't know anything.
