Transmission Trouble
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CampInMyTaco, Feb 2, 2023.
  1. Feb 17, 2023 at 8:22 AM
    #41
    CampInMyTaco
    CampInMyTaco [OP] Member
    2017 Tacoma TRD Sport
    So both the independent transmission place and Toyota recommended replacing the transmission. The indy recommended a three part service of transmission fluid and some kind of fix leak liquid? I can’t remember exactly what it was called but the cost is over $500 with no guarantee it will work. So I’m leaning towards replacing the transmission. Doesn’t sound like they can just replace the converter. My plan is to have Toyota order the transmission which is in backorder and if it takes longer than two weeks have the fluid service done to at least buy some time.
  2. Feb 17, 2023 at 8:42 AM
    #42
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, i read your post. just not sure of the long term effects of running friction modifier on the torque converter clutch.
    joba27n likes this.
  3. Feb 17, 2023 at 9:52 AM
    #43
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I would personally skip the additive, you're not a very high milage vehicle plus as I said in both my personal and professional experience you'd be surprise how much the quality and condition of the fluid will change a transmission from paperweight to brand new
    not as common with newer vehicles and I don't know how Toyota autos work but flushing the cooler could also help but usually a plugged cooler in my experience manifest as the vehicle stalling when coming to a stop after a highway drive because the torque converter doesn't release making it act like a clutch in a manual when you come to a full stop without disengaging it
  4. Feb 23, 2023 at 5:08 PM
    #44
    CampInMyTaco
    Another update. Because the transmission was on backorder, I decided to have the triple fluid service with shudder fix done. Drive it for about 30 min today after the service and not a single shudder. Night and day. They told me to monitor for a week and call them with an update. If all goes well for a year, they recommend another fluid service. We’ll see how it goes but for now the total replacement is on hold.
  5. Feb 23, 2023 at 5:32 PM
    #45
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Nice it worked out . This is another example of the importance of trans fluid change at 60t miles and not as Toyota said as a lifetime fluid . I’m sure I’ll be flamed on this but it is what it is .
    joba27n, Canadian Caber and TexasG like this.
  6. Mar 8, 2023 at 1:15 PM
    #46
    CampInMyTaco
    Update after 500 miles. The truck is driving like normal and the shudder or “rumble strip” has not returned. Transmission tech said to give it three more weeks before I do any other maintenance.
  7. Mar 8, 2023 at 1:25 PM
    #47
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    So to recap, you did a 3 part fluid change and it fixed your problems?
  8. Mar 8, 2023 at 1:45 PM
    #48
    CampInMyTaco
    That’s what they did, yes. And an additive.
    Off Topic Guy likes this.
  9. Mar 8, 2023 at 1:55 PM
    #49
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Exlnt! Now, change out the rear diff oil for a real eye popper
    joba27n likes this.
  10. Mar 8, 2023 at 1:58 PM
    #50
    trouble_shooting
    trouble_shooting Active Member
    Trig
    2021 TRD Off-Road
    Thanks for the update! Glad to hear the positive outcome. Happy trails!:D
    Steves104x4 likes this.
  11. Mar 8, 2023 at 5:51 PM
    #51
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    So what’s the name of the magic juice they put in to fix the shudder?
    MGMDesertTaco likes this.
  12. Mar 8, 2023 at 5:54 PM
    #52
    MGMDesertTaco
    X2 What exactly did they put in the trans? Lucas trans fix?
  13. Mar 9, 2023 at 5:24 AM
    #53
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I had a 5.0 explorer that had the same issue at 50k miles. Added the shudder fix and problem instantly went away. I changed all the fluid right after that and every 50k there after.
    Put 200k on it without any other trans problems and the shudder never came back.
