Transmission TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 5Sport, Nov 5, 2009.
  1. May 19, 2010 at 7:12 AM
    #641
    taco_man
    taco_man Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    with a lift kit on my truck will they still do tsb for my delayed ingaging and for the leaf springs?
  2. May 19, 2010 at 7:46 AM
    #642
    Twirlin
    Twirlin Nature just gets the blow-by
    WI
    '10 TRD Sport Mag Grey
    yes, that shouldn't matter. Lift won't void the warranty all by itself. They only void the warranty if the lift kit is proven to cause some failure. However, since you have a lift, the alignment may not come out tight without new UCAs.
  3. May 19, 2010 at 7:49 AM
    #643
    taco_man
    Austin
    Houston
    09 texas edition
    already have the new ucas. just want to get rid of the sag in the rear because when i put my 4 wheeler in the back of my truck it goes down about 2 inches. not cool!
  4. May 19, 2010 at 11:02 AM
    #644
    rufuss11
    rufuss11 Well-Known Member
    CA
    2010 Double cab Offroad
    5100's set at 1.75, aero turbine
    How long will it take the dealer to perform this tsb?
  5. May 19, 2010 at 3:15 PM
    #645
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    it took the dealer about 2 hours to get mine done. that was because i had people in front of me, i think the actual work time is about 15 minutes.
  6. May 20, 2010 at 9:27 AM
    #646
    taco_truck
    taco_truck Member
    so.cal
    '09 DCLB 4x4
    just took mine in to the dealer...they said they would check the tranny fluid and reflash...hopefully it will remedy the annoyance.
  7. May 22, 2010 at 2:41 PM
    #647
    taco_truck
    taco_truck Member
    so.cal
    '09 DCLB 4x4
    got my truck back from the dealer and the confused tranny is not confused anymore. thanx everyone.
  8. May 28, 2010 at 1:08 PM
    #648
    ianc
    ianc Well-Known Member
    ian
    mass
    tacoma sr5 trd
    That BS thats a years worth of driving. Is your truck retarded?
  9. Jun 9, 2010 at 12:54 PM
    #649
    DallasPre
    DallasPre Well-Known Member
    Dallas
    White 2wd
    5%tint,kick ass Stereo,remote start/alarm,K&N intake,Katzkin seat covers,Custom bed mat,de-badged,painted grillbadge blk,relocate horn,rearview camera mod,seat-belt chime mod
    I had the trans prob... printed up the tsb.. took it to toyota.. 30min later its like driving a whole new truck. i guess i was getting use to the delayed shift.. anyhow just wanted to say thanks for the info and if you are having the prob and havent done it than go do it.
  10. Jun 17, 2010 at 5:02 AM
    #650
    madhatter160
    madhatter160 Member
    09 Double Cab TRD Off-Road
    Trip report:
    At the above mentioned oil change, the dealership said they'd look at the problem, but never found anything. They attributed it to the transmission still "learning" (it was the truck's 5k mi oil change).
    For the 10k mi oil change I went to the same dealership, but this time brought a print out of the applicable TSB. As soon as I showed the technician the TSB, he noted the number and said they'll take care of it. About an hour later, I got the truck back and the technician said that they test drove it and could reproduce the problem. So, they flashed the PCM as per the TSB. I could immediately tell a difference when driving it. It drives like I expected it to now! It has only been a day since the work was performed. I'll keep an eye on how it performs.
    So, lesson learned: bring a hard copy of the TSB and keep at it!
  11. Aug 12, 2010 at 2:39 PM
    #651
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    I don't understand Toyota, if they knew in Dec 09 of this, why is my Tacoma with build date 07/10 didn't come with the new springs and the updated software??
    2010 Toyota Tacoma
    TRD Sport
    V6
  12. Aug 12, 2010 at 3:39 PM
    #652
    JKD
    JKD Well-Known Member
    Since they are referenced in TSBs, they are probably only for use in resolving customer complaints. The transmission programming may have been added to recent software updates, based on my experience with the gas pedal recall and better shifting afterwards. Maybe they put a new major software update into production vehicles after yours was built.
  13. Aug 22, 2010 at 4:05 PM
    #653
    monte1985
    monte1985 Well-Known Member
    Stan
    Lancaster NY
    09 Tacoma Dbl Cab 4.0 S/C
    Supercharger, Magnaflow Exhaust. Audio System . Gauges TRD CAI
    I have this problem going on . If i shift manually a couple of times it seems to learn that for a bit and then goes back to the crazy shifting. Does this work for a truck with the TRD supercharger? Do they have a new flash for that. Well prob going to make an appt to get the recall for the floor mats done and have them do this too.
  14. Aug 30, 2010 at 5:00 AM
    #654
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    Got my 09 re flashed as per the TSB for the second time. Had it flashed a long time ago and the tranny lag came back.This time I hope the tranny re flash stays because the tranny shifting is spot on with the timing,no lag at all. also got new plugs with my 30k maintenance, smooth and nice.
  15. Sep 8, 2010 at 6:33 PM
    #655
    mike686
    mike686 Well-Known Member
    Michael
    Waldorf
    10 Tacoma TRD Off Road
    See Build Thread
    Bump, sorry like two week bump, looking for the tsb tranny ecm reflash number, i mightve passed by it on here, if anyone knows it on hand that would be great
  16. Sep 8, 2010 at 6:40 PM
    #656
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    will this apply to the 06???
  17. Sep 8, 2010 at 7:12 PM
    #657
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
  18. Sep 9, 2010 at 6:32 AM
    #658
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    Can a Moderator put this file in the TSB section please. Also there is another one on the second post of this thread.
    The TSB section needs to be updated and these liks will help a little
    Thank you
    PS: Sorry about the jacked thread
  19. Sep 27, 2010 at 1:09 AM
    #659
    Lexxx_2011
    Lexxx_2011 Active Member
    South Mississippi
    2011 DC TRD Off-Road Magnetic Grey
    Does anyone have this same TSB for the 2011's? I have the 2011 Off-road and it has the hard shifting and lagging. Thanks.
  20. Mar 5, 2011 at 9:11 AM
    #660
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    X2. Anyone has info on this TSB conserning the 2011 ?
