Transmission Tuning 2020 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by collins2471, Mar 9, 2021.
  1. Mar 9, 2021 at 4:18 AM
    collins2471
    collins2471 [OP] New Member
    Matthew
    2020 Sliver Tacoma TRD Sport
    Looking for a specialist that works on transmission tuning for 2020 tacoma’s in Maryland.
    KLC likes this.
  2. Mar 9, 2021 at 4:25 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    9mmMike and Clearwater Bill like this.
  3. Mar 9, 2021 at 4:26 AM
    Clearwater Bill
    Billy
    Largo Florida
    Let us know where this wiley magician is found......
  4. Mar 9, 2021 at 5:13 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Transmission tuning? What are you trying to do? The 2020 transmission operates fine.
    Junkhead likes this.
  5. Mar 9, 2021 at 5:35 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
  6. Mar 9, 2021 at 5:46 AM
    AjaxTaco
    AjaxTaco Well-Known Member
    2020 Taco OR
    The stock transmission settings even after the latest TSB are hot garbage. I got vfTuner and flashed their 2.0 stock tune and it operates as it should have from the factory. The acceleration and shift points are spot on now. You can pay ~$700 for the software and tune pack (totally worth the cost), or you can do a search in the forum and find someone near you that may just charge you the cost of the credits and a small fee.
    I have a 23-mile commute to work, mostly freeway with hilly terrain. I seriously thought I made a mistake getting my Taco. The truck felt lethargic, and if I had the cruise control set, it would hold at 3000+ rpm for about 10-15 seconds after cresting a hill. Now, it downshifts and upshifts like a normal vehicle and doesn't feel labored going up hills.
    tonered and SR-71A like this.
  7. Mar 9, 2021 at 6:19 AM
    Devious6
    Mark
    I have to disagree with you. I live in northeast PA and drive a combination of moderate to steep hills both highway and back roads. I never had any real issues with my transmission but did find it to be even better after the TSB. We all have different experiences and expectations - I'd suggest going about any changes in a sequential manner and see whether the TSB is the solution before adding an aftermarket tuning. Just my own $.02.
  8. Mar 9, 2021 at 7:51 AM
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Some find the Toyota transmission tuning to be fine. Others find it to be hot garbage. I am in the latter group. If you are too, check out the many OV Tuning threads. It can be fixed. Based on my experience one of the main causes is that the shifting learning logic can end up in a wonky place for some of us. My '18, sometimes it would downshift to 5,000rpm with a feather on the pedal, other times it would hold 1,200 rpm even with a brick on the accelerator. No longer now that I've tuned it.
    tonered and AjaxTaco like this.
  9. Mar 9, 2021 at 7:54 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    So post in the MARY LAND section
  10. Mar 9, 2021 at 8:10 AM
    zoo truck
    None
    3K rpm...must be some long steep hills with a load if you have to do that. My 2020 goes up hills fine here in connecticut at 2200 rpm at 55-60 mph even with a couple hundred lbs. in the bed. I've rarely seen more than 2500 rpm towing my boat or utility trailer. I'm not driving at 80+...i'll own something else for that.
  11. Mar 9, 2021 at 8:13 AM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    +1 for doing the OVtune.
    OP - I'm in Maryland and will flash your truck for $250
    tonered likes this.
  12. Mar 9, 2021 at 8:13 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Never over 2500 RPM? That's worse than Chinese water torture
  13. Mar 9, 2021 at 8:15 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    My opinion on the shifting is:
    If you driving style is for maximizing fuel economy for the truck drives fine, if you have even a slightly heavy foot, it doesnt shift when you want it to
  14. Mar 9, 2021 at 8:19 AM
    AjaxTaco
    2020 Taco OR
    I average 75-79 mph and that is keeping up with the flow of traffic. The stock taco is optimized and geared for 55-60 mph, but at 75 mph speeds, a pure stock set up leaves a lot to be desired. I’m not a speed demon out there but with the tune it is nice hitting freeway speeds from the on ramp without having to mash down on the throttle.
  15. Mar 9, 2021 at 8:30 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Have you even been outside of Connecticut?
    GarlicFarts likes this.
  16. Mar 9, 2021 at 8:31 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    *Laughs in Manual Transmission*
    AjaxTaco and Dank Donkeh Luvver like this.
  17. Mar 9, 2021 at 8:31 AM
    zoo truck
    None
    Truck makes good power from 1500 rpm up. Blows my mind why others are complaining. I'm not one that ever drives past 75 mph.
  18. Mar 9, 2021 at 8:35 AM
    dunlap837
    2018QSDCLBSR5
    I judge that you have low expectations, and that's fine. Others have higher expectations, and that's fine too. The good news is that the aftermarket support exists to raise the performance of the truck to meet those higher expectations.
    Skydvrr likes this.
  19. Mar 9, 2021 at 8:36 AM
    zoo truck
    None
    Yep, all over the bershires and taconic's of ma. and ny. I actually live just south of the berkshires, and at the foot of the taconic's in the nw corner of connecticut.
  20. Mar 9, 2021 at 8:36 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    1500?! :eek:
    I drive 80-85mph every day too and from work. Driving slow is the worst
