transmission used/rebuild recommendations? 1st gen
Discussion in 'Northern California' started by edbranch, Feb 16, 2025.
  1. Feb 16, 2025 at 5:51 PM
    edbranch
    edbranch [OP] Active Member
    ed
    1999 Tacoma xtra cab 3.4 2 wh drive man
    I have a 99 Tacoma 3.4 2wd manual 5sp that is popping out of first. Hoping for something on the more economical side used or repaired. Anyone had luck finding something around here (south bay)? I changed the fluid and it improved but need it better for a behind the wheel drive test. thx
  2. Feb 17, 2025 at 1:36 PM
    10YSON
    10YSON Well-Known Member
    GREG
    2ND GEN 4X4 LT
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
  3. Feb 17, 2025 at 2:45 PM
    edbranch
    ed
    thanks for the reply.
  4. Feb 17, 2025 at 8:28 PM
    rglsr
    rglsr Well-Known Member
    California
    The 2WD 3.4 manual trans is a R150, the 4WD 3.4 manual is a R150F, similar trans but F denotes the transfer case I think. (so not applicable to 2WD)
    The 2WD 3.4 V6 manual 1st gen Tacomas were not so common (and were all 5 lug), you might try car-part.com.
  5. Feb 18, 2025 at 12:54 PM
    edbranch
    ed
    thx for the reply...yes it's a hard one to find. Might end up getting it rebuilt. Mine has only 160K on it
